User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Configuring Component Interaction
This section uses the tab list and line chart as an example to describe the component interaction configuration. In DLV, component interaction configuration indicates that a component transfers parameters to other components when responding to user operations or automatically triggering updates. The parameters can be used as dynamic variables during data query in other components. If you can select on the Interaction tab page of a component, the component supports the interaction function. Otherwise, the component does not support the interaction function.
- You have enabled the required service and created a database instance.
- The corresponding data has been stored in the database instance.
Adding and Configuring Components
- Open the screen development page, click the Interaction icon, and select Geography Search in the Components list.
Figure 3 Selecting the geographical search component
- On the Pattern panel, configure the geographical search component. In this example, use the default settings.
Figure 4 Configuring the geographical search component
- Switch to the Data panel and set the data of the geographical search component.
Figure 5 Setting the data of the geographical search component
- Switch to the Interaction panel and define and use interaction variables.
Figure 6 Defining and using interaction variables
- In the component list on the left, choose Charts > Bar.
Figure 7 Selecting a bar chart component
- On the Pattern tab page, configure the bar chart pattern. This example uses the default settings.
Figure 8 Configuring the bar chart pattern
- Switch to the Data tab page and configure the bar chart.
Previewing and Publishing Screens
- In the upper right corner of the screen development page, click
to preview the screen.
- If you reset the geographical location in the geographical search, the bar chart displays only the data of the corresponding location.
- After ensuring that interaction works, click
in the upper right corner of the screen development page, configure publish parameters, and then share the screen with other users.
Figure 11 Publishing and sharing the screen
Enabling Interaction
To enable the interaction function, you can select on the Interaction tab page. When the value of the tab component changes, the value is transferred to other components.
Field Mapping
Configure field mappings When variable ${data} is used in other components, the value mapped by label can be obtained.
