User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Before establishing a data connection to RDS for GaussDB, ensure that the following conditions are met:
- You have obtained the IP address, port number, username, and password of RDS for GaussDB.
- To enable network communication between DLV and RDS, you can use a VPC connection as a network proxy. Create a VPC connection by referring to instructions in Managing VPC Connections.
Creating an RDS for GaussDB Data Connection
- Log in to the DLV console.
- On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
Figure 1 Creating a data connection
- In the New Data Connection dialog box, set Data Source Type to RDS for GaussDB and set the related parameters.
Figure 2 Creating an RDS for GaussDB data connection
Table 1 describes the RDS for GaussDB data connection parameters.
Table 1 RDS for GaussDB data connection parameters Parameter
Name
Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
Instance ID
ID of the database instance.
Host
After an instance ID is selected, an intranet IP address of a database is automatically matched. The domain name cannot be changed.
Port
After an instance ID is selected, a database port is automatically matched. The port cannot be changed.
Username
Username of the database. The database user must have permission to access data tables and metadata.
Password
Password of the database user.
Agent
Select an available connection agent, such as VPC connection, CDM proxy, or Internet. To use the VPC connection, create a VPC connection by referring to instructions in Managing VPC Connections.
- Click OK.
Using GaussDB Data Sources
You can configure and use GaussDB data sources by referring to the instructions in Using DWS Data Sources.
