Creating RDS for SQL Server Data Connections
Updated on 2025-01-22 GMT+08:00
Before establishing a data connection to RDS for SQL Server, ensure that the following conditions are met:
  • You have obtained the address, port number, username, and password of RDS for SQL Server.
  • To enable network communication between DLV and RDS, you can use a VPC connection as a network proxy. Create a VPC connection by referring to instructions in Managing VPC Connections.
Creating an RDS for SQL Server Data Connection
  1. Log in to the DLV console.
  2. On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
    Figure 1 Creating a data connection
  3. In the New Data Connection dialog box, set Data Source Type to RDS for SQL Server and set the related parameters.
    Figure 2 Creating an RDS for SQL Server data connection
    Table 1 describes the RDS for SQL Server data connection parameters.
    Table 1 RDS for SQL Server data connection parameters
    Name
    Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
    Instance ID
    ID of the database instance.
    Domain Name
    After an instance ID is selected, an intranet IP address of a database is automatically matched. The domain name cannot be changed.
    Port
    After an instance ID is selected, a database port is automatically matched. The port cannot be changed.
    Username
    Username of the database. The database user must have permission to access data tables and metadata.
    Password
    Password of the database user.
    Agent
    Select an available connection agent, such as VPC connection, CDM proxy, or Internet. To use the VPC connection, create a VPC connection by referring to instructions in Managing VPC Connections.
    Database
    You can select a database from the Database drop-down list.
  4. Click OK.
Using RDS for SQL Server Data Sources
You can configure and use RDS for SQL Server data sources by referring to the instructions in Using DWS Data Sources.
