User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Managing Workspaces
A workspace enables its administrator to manage user (member) permissions, resources, and underlying compute engines of DLV.
Each team has an independent workspace.
You can manage workspaces, data connections, screens, screen combinations, and applications only after being added to workspaces and assigned permissions.
In the workspace management, the administrator can add other users to a workspace and assign roles to them, such as Administrator, Developer, Analyst, and Visitor that are preset on DLV.
Background
- Cloud accounts or users with the DLV FullAccess can perform all operations on DLV by default.
- Only the users with the DLV FullAccess or Tenant Administrator permission can create, delete, or modify workspaces and set the default workspace.
The Tenant Administrator permission has all cloud service administrator permissions except the IAM management permission. For security purposes, you are not advised to grant this permission to IAM users. Exercise caution when performing this operation.
- An IAM user can access a workspace only after being added as a member of the workspace.
Creating Workspaces
- Log in to the DLV console.
- In the navigation tree on the left, click Control Center > Workspace.
- On the Workspace page, click
to create a workspace.
Figure 1 Workspace - In the Create Workspace dialog box, set the following parameters and click OK.
- Workspace Name: A workspace name can contain only letters, numbers, underscores (_), and hyphens (-), and cannot exceed 32 characters.
- Description: Description of the workspace.
Figure 2 Creating a workspace
Setting the Default Workspace
- In the navigation tree on the left, click Control Center > Workspace. The Workspace page is displayed.
- In the workspace list, click the workspace to be set, click
, and choose Set to Default Workspace from the shortcut menu.
Figure 3 Setting the default workspaceAfter the setting is completed, the Default icon is displayed next to the workspace name.
Figure 4 Default workspace
Switching Workspaces
- Click the workspace drop-down list in the upper left corner of the page. On the displayed workspace panel, click the workspace that you want to switch to.
Figure 5 Switching a workspace
Modifying Workspaces
- In the workspace list, select the workspace to be modified and click Edit.
Figure 6 Editing a workspace
- In the Workspace Info area, set the following parameters and click Save.
Figure 7 Modifying the workspace information
Deleting Workspaces
After a workspace is deleted, all resources in the workspace are deleted and cannot be recovered. Exercise caution when performing this operation.
- In the workspace list, click the workspace to be deleted, click
, and choose Delete from the shortcut menu.
Figure 8 Deleting a workspace - In the displayed dialog box, select After you delete this workspace, all resources in it cannot be restored, and click OK.
