- What's New
- Function Overview
Product Bulletin
- Vulnerability Notice
Product Notices
- [Notice] Starting OBT for DDS Cluster 5.0 on Nov 5, 2024
- [Notice] Huawei Cloud DDS Replica Set 5.0 Will Be Released Commercially on Oct 11, 2024
- [Notice] Huawei Cloud DDS 3.4 Will Be Discontinued on Oct 11, 2024
- [Notice] Starting OBT for DDS 5.0 on July 24, 2024
- [Notice] Specifications with CPU-Memory Ratio of 1:8 Will Be Available for x86-Powered Enhanced II Replica Set Instances and Cluster Shards on February 15, 2023
- [Notice] DDS 4.4 OBT Invitation
- [Product Discontinuation Notice] Huawei Cloud Document Database Service (DDS) Single Node Instances Will Be Discontinued on July 15, 2023
- [Notice] Huawei Cloud DDS 4.4 Will Be Released Commercially on Oct 08, 2023
- Version Description
- Product Release Notes
Service Overview
- Infographics
- What Is DDS?
- Advantages
- Comparison Between DDS and On-Premises Databases
- Typical Application Scenarios
- Functions and Features
- System Architecture
- Instances
- Notes and Constraints
- Basic Concepts
- Compatibility
- Security
- Permissions
- Related Services
- Mapping Between DDS Versions and Community Versions
- Billing
- Getting Started
User Guide
- Buying an Instance
Connecting to a DB Instance
- Connecting to a Cluster Instance
- Connecting to a Replica Set Instance
- Connecting to a Single Node Instance
- Data Migration
- Performance Tuning
- Permissions Management
- Instance Lifecycle Management
Instance Modifications
- Changing an Instance Name
- Changing an Instance Description
- Modifying an Instance Tag
- Changing the Name of the Replica Set in the Connection Address
- Upgrading a Minor Engine Version
- Upgrading a Major Engine Version
- Scaling Up Storage Space
- Changing an Instance Class
- Changing Cluster Instance Nodes
- Changing Replica Set Instance Nodes
- Configuring the Maintenance Window
- Changing an AZ
- Updating the OS of a DB Instance
Data Backups
- Backup Principles and Solutions
- Configuring an Automated Backup Policy
- Configuring an Incremental Backup Policy
- Configuring the Cross-Region Backup Policy
- Setting Backup Method for a DB Instance
- Creating a Manual Backup
- Deleting a Manual Backup
- Deleting an Automated Backup
- Stopping a Backup
- Downloading a Backup File
Data Restorations
- Solutions
- Restoring Data to a New Instance
- Restoring Data to the Original Instance
- Restoring Data to a Point in Time
- Restoring Data to an On-Premises Database
- Restoring Data of Enhanced Edition
Parameter Template Management
- Overview
- Creating a Parameter Template
- Modifying DDS DB Instance Parameters
- Viewing Parameter Change History
- Exporting a Parameter Template
- Comparing Parameter Templates
- Replicating a Parameter Template
- Resetting a Parameter Template
- Applying a Parameter Template
- Viewing Application Records of a Parameter Template
- Modifying the Description of a Parameter Template
- Deleting a Parameter Template
- Connection Management
- Database Usage
- Data Security
- Monitoring and Alarm Reporting
- Auditing
- Logs
- Task Center
- DBA Assistant
- SQL Execution Control
- Cross-AZ Disaster Recovery
- Tags
- Quotas
- DDS Usage Suggestions
- Developer Guide
Best Practices
- Overview
- Security Best Practices
- Common Methods for Connecting to a DDS Instance
- From Other Cloud MongoDB to DDS
- From On-Premises MongoDB to DDS
- From ECS-hosted MongoDB to DDS
- How Do Replica Sets Achieve High Availability and Read/Write Splitting?
- Sharding
- How Do I Improve DDS Performance by Optimizing SQL Statements?
- How Do I Prevent the dds mongos Cache Problem?
- How Do I Solve the High CPU Usage Issue?
- How Do I Troubleshoot High Memory Usage of DDS DB Instances?
- What Can I Do If the Number of Connections of an Instance Reaches Its Maximum?
- Creating a User and Granting the Read-Only Permission to the User
- Proper Use of Data Definition Languages (DDL) Statements
- How Is a DDS Node Going to Be Disconnected and What Can I Do?
- Security White Paper
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs V3.0 (Recommended)
- Querying the API Version
- Querying Database Version Information
- Querying Database Specifications
- Querying the Database Disk Type
DB Instance Management
- Creating a DB Instance
- Restarting a DB Instance
- Deleting a DB Instance
- Querying Instances and Details
- Adding Nodes for a Cluster Instance
- Modifying DB Instance Specifications
- Performing a Primary/Secondary Switchover in a Replica Set Instance
- Enabling or Disabling SSL
- Modifying a DB Instance Name
- Changing a Database Port
- Changing a Security Group
- Binding an EIP
- Unbinding an EIP
- Changing a Private IP Address
- Creating Shard or Config IP Addresses of a Cluster Instance
- Configuring Cross-CIDR Access for a Replica Set
- Querying AZs to Which an Instance Can Be Migrated
- Migrating a DB Instance to Another AZ
- Setting the Recycle Bin Policy
- Adding Nodes to a Replica Set Instance
- Adding a Read Replica to an Instance
- Upgrading the Database Patch
- Enabling or Disabling Monitoring by Seconds
- Querying Second-Level Monitoring Configurations
- Querying the Recycling Policy of a DB Instance
- Querying DB Instances in the Recycle Bin
- Checking for Weak Passwords
- Querying the Estimated Database Patch Upgrade Duration
- Querying Instance Disk Information
- Obtaining the SSL Certificate Download Address
- Querying the Name of the Replica Set in the Connection Address
- Deleting Instance Nodes
- Deleting a Read Replica of an Instance
- Querying Access Across CIDR Blocks for a Replica Set Instance
- Querying LTS Log Configurations
- Associating an Instance with an LTS Log Stream
- Disassociating an Instance from an LTS Log Stream
- Configuring an Autoscaling Policy for Storage Space
- Querying the Autoscaling Policy of Storage Space
- Upgrading the Minor Versions of DB Instances in Batches
Backup and Restoration
- Querying the Backup List
- Querying an Automated Backup Policy
- Setting an Automated Backup Policy
- Restoring Data to a New DB Instance
- Obtaining the Link for Downloading a Backup File
- Querying the Restoration Time Ranges
- Obtaining the List of Databases That Can Be Restored
- Obtaining the List of Database Collections That Can Be Restored
- Restoring Data to the Original DB Instance
- Restoring Databases and Tables to a Point in Time
- Stopping a Backup
- Deleting Manual Backups in Batches
Parameter Configuration
- Obtaining Parameter Templates
- Obtaining Details About a Parameter Template
- Modifying a Parameter Template
- Obtaining Parameters of a Specified DB Instance
- Modifying Parameters of a Specified DB Instance
- Querying Available DB Instances
- Checking Whether a Parameter Template Name Is Unique
- Viewing Parameter Change History of an Instance
Log Information Queries
- Querying Database Slow Logs (New)
- Obtaining Links for Downloading Slow Query Logs
- Showing Original Slow Logs
- Querying Database Error Logs (New)
- Obtaining Links for Downloading Error Logs
- Configuring SQL Audit
- Querying SQL Audit Policy
- Obtaining the Audit Log List
- Obtaining Links for Downloading Audit Logs
- Querying the Switch of Show Original Log
- Deleting Audit Logs
- Tag Management
Managing Databases and Users
- Creating a Database User
- Creating a Database Role
- Querying Details About Database Users
- Querying the Database Role List
- Changing the Password of a Database User
- Checking the Password for Logging In to a Database
- Querying Cluster Balancing Settings
- Enabling or Disabling Cluster Balancing
- Setting the Activity Time Window for Cluster Balancing
- Deleting a Database User
- Deleting a Database Role
- Querying Databases
- Quota Management
- Database O&M
- Task Management
- API V3 (Unavailable Soon)
- Examples
- Appendix
- SDK Reference
Product Consulting
- What Is the Relationship Between DDS and MongoDB Community Edition?
- Q&A About Switching Storage Engine to RocksDB for DDS 4.2 and Later Versions
- What Are the Differences Between DDS and GeminiDB Mongo?
- What Precautions Should Be Taken When Using DDS?
- What Is the Availability of DDS DB Instances?
- Will My DDS DB Instances Be Affected by Other Users' DDS DB Instances?
- Does DDS Support Multi-AZ Deployment?
- Can I Change the VPC for a Created Instance?
- Can I Change the Region for a Created Instance?
- What Is Hidden Node?
- Database Versions
- Resource Freezing, Release, Deletion, and Unsubscription
Resource and Disk Management
- Which Items Occupy the Storage Space of DDS Instances?
- Which Types of Logs and Files Occupy DDS DB Instance Storage Space?
- Why Is the Storage Space Usage Displayed on the GUI Smaller Than the Actual Usage?
- Why Does Available Disk Space Not Increase After Data Is Deleted?
- Why Is the Resident Memory of a 4 vCPUs/8 GB Memory Replica Set Instance Only 4 GB?
- Capacity Expansion and Specification Changes
Database Performance
- When Will a Primary/Standby Switchover Be Triggered for a Cluster or Replica Set?
- High Storage Usage
- What Is the Time Delay for Primary/Secondary Synchronization in a Replica Set?
- How Is Data Transferred Between the Primary and Secondary Nodes of a Replica Set?
- How Do I Clear an Alarm Saying the Shard Memory Usage Exceeds 90%?
- What Can I Do If a Query Error Is Reported After Data Is Written Into the DDS Cluster?
- Database Permissions
Creation and Deletion
- How Do I Select Instance Specifications and Nodes?
- Why Is an Instance Not Displayed on the Console After It Is Created?
- Can I Use a Template to Create DDS DB Instances?
- Why Is Data Missing from My Database?
- Will My Backups Be Deleted If I Delete My Cloud Account?
- What Are the Differences Between Instance Deletion and Unsubscription?
Database Connection
- What Should I Do If I Fail to Connect to a DDS Instance?
- How Do I Query and Limit the Number of Connections?
- What Should I Do If the ECS and DDS Are Deployed in Different VPCs and They Cannot Communicate with Each Other?
- Do Applications Need to Support Automatic Reconnecting to the DDS Database?
- How Do I Create and Log In to an ECS?
- Installing a Client
- Database Usage
- Database Migration
- Database Storage
- Database Parameters
- Backup and Restoration
- Network Security
Product Consulting
Troubleshooting
- Overview
- DDS Instance Node Fault Handling Mechanism
- Connection Failure Message: network error while attempting to run command 'isMaster'
- Connection Failure Messages: No route to host and connection attempt failed
- Connection Failure Message: Authentication failed
- Connection Failure Message: couldn't connect to server
- Connection Failure Message: cannot list multiple servers in URL without 'replicaSet' option
- Connection Failure Message: Timeout while receiving message
- Connection Failure Message: exception: login failed and U_STRINGPREP_PROHIBITED_ERROR
- Change History
- Videos
- Glossary
More Documents
- Introduction
- Logging In to the DDS Console
- Getting Started with Clusters
- Getting Started with Replica Sets
- Migrating Data
- Account Management
Instance Management
- Changing a DB Instance Name
- Adding Cluster Instance Nodes
- Reverting Cluster Instance Nodes
- Changing the CPU or Memory of a Cluster DB Instance
- Changing the CPU or Memory of a Replica Set DB Instance
- Manually Switching the Primary and Secondary Nodes of a Replica Set
- Exporting DB Instance Information
- Restarting a DB Instance or a Node
- Recycling a DB Instance
- Backup and Restore
- Parameter Group Settings
- Task Center
- Auditing
- Log Management
- Tag
- Product Consulting
- Database Performance
- Creation and Deletion
Database Connection
- Can an External Server Access the DDS DB Instance?
- What Is the Number of DDS Database Connections?
- What Should I Do If an ECS Cannot Connect to a DDS DB Instance?
- What Should I Do If a Database Client Problem Causes a Connection Failure?
- What Should I Do If a DDS Server Problem Causes a Connection Failure?
- How Can My Applications Access a DDS DB Instance in a VPC?
- How Can I Install a MongoDB Client?
- How Do I Install Robo 3T?
- Database Usage
- Database Storage
- Database Parameter Modification
- Network Security
- Resource Monitoring
- Log Management
- Which Commands are Supported or Restricted by DDS?
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
- Querying All DB Instance Specifications
- Binding an EIP
- Unbinding an EIP
- Tag Management
- Appendix
- Change History
User Guide (Paris Region)
- Introduction
- Migrating Data
Instance Management
- Task Center
- Auditing
- Log Management
- Tag
Database Connection
- Database Usage
- Database Storage
- Network Security
- Log Management
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
- Binding an EIP
- Unbinding an EIP
- Appendix
- Change History
- Introduction
- Migrating Data
Instance Management
- Task Center
- Auditing
- Log Management
- Tag
Database Connection
- Database Usage
- Database Storage
- Network Security
- Log Management
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
- Changing the Administrator Password
- Binding an EIP
- Unbinding an EIP
- Tag Management
- Appendix
- Change History
On this page
Show all
Help Center/
Document Database Service/
User Guide (ME-Abu Dhabi Region)/
Parameter Group Settings/
Creating a Parameter Group
DB parameter groups act as a container for engine configuration values that are applied to one or more DB instances. This section describes how to create a parameter group to manage your DB instance configurations.
- DDS does not share parameter group quotas with RDS.
- Each account can create up to 100 DDS parameter groups for the cluster and replica set instances.
Cluster
- Log in to the DDS console.
- In the navigation pane on the left, click Parameter Group Management.
- On the Parameter Group Management page, click Create Parameter Group.
- Specify DB Engine Version, DB Instance Type, Node Type, Parameter Group Name, and Description and then click OK.
- Node Type: specifies the node type that this parameter group will apply to. For example, to create a parameter group applying to config, select config.
- Parameter Group Name: specifies the parameter group name, which is a string of 1 to 64 characters composed of only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.).
- Description: contains a maximum of 256 characters and cannot contain the carriage return character and the following special characters: >!<"&'=
- On the Parameter Group Management page, view and manage parameter groups on the Clusters tab.
Replica Set
- Specify DB Engine Version, DB Instance Type, Parameter Group Name, and Description and then click OK.
- On the Parameter Group Management page, view and manage parameter groups on the Replica Sets tab.
Parent topic: Parameter Group Settings
