Scaling Up Storage Space
This section describes how to scale up the storage space of a DB instance to suit your service requirements.
- You can scale up a DB instance a maximum of eight times.
- You cannot scale up a DB instance in Creating, Changing instance class, Adding node, or Deleting node status.
- Storage space can only be scaled up. It cannot be scaled down.
- You cannot scale up the storage space of a config for the cluster instances.
- During the scale-up process, the DB instance will not restart, and your services will not be interrupted.
Cluster
- Log in to the DDS console.
- On the Instance Management page, click the target cluster instance.
- In the Node Information area on the Basic Information page, click the shard tab, locate the target shard, and click Scale Storage Space in the Operation column.
- On the displayed page, specify the desired storage space, and click Submit.
You must add a minimum of 10 GB each time you scale up, and only multiples of 10 GB are allowed. The maximum amount of storage space is 2000 GB.
- On the displayed page, confirm the storage space.
- If you need to modify your settings, click Previous to go back to the page for you to specify details.
- If you do not need to modify the specifications, click Submit to scale up the storage space.
- Check the scaling-up result.
- This process takes about 3 to 5 minutes. The status of the DB instance in the instance list is Scaling up.
- In the upper right corner of the DB instance list, click
to refresh the list. The instance status changes to Available. - In the Node Information area on the Basic Information page, click the shard tab and check whether the scale up was successful.
Replica Set
- On the Instance Management page, locate the target replica set instance and click Scale Storage Space in the Operation column.
to refresh the list. The instance status changes to Available. - In the Storage Space area on the Basic Information page, check whether the scaling up is successful.
