Metrics
This section describes metrics reported by DDM to Cloud Eye as well as their namespaces, metric list, and dimensions. You can use APIs provided by Cloud Eye to query the metric information generated for DDM.
Metrics
| Metric Name | Description | Value Range | Monitored Object | Monitoring Interval (Raw Data) |
| CPU Usage | CPU usage of the DDM instance node | 0–100% | DDM nodes | 1 minute |
| Memory Usage | Memory usage of the DDM instance node. | 0–100% | DDM nodes | 1 minute |
| Network Input Throughput | Incoming traffic per second of the DDM instance node | ≥ 0 byte/s | DDM nodes | 1 minute |
| Network Output Throughput | Outgoing traffic per second of the DDM instance node | ≥ 0 byte/s | DDM nodes | 1 minute |
| QPS | Requests per second of the DDM instance node | ≥ 0 counts | DDM nodes | 1 minute |
| Read/Write Ratio | Read/Write ratio of the DDM instance node within n each monitoring period | 0-100% | DDM nodes | 1 minute |
| Reads | Read operations of the DDM instance node within each monitoring period | ≥ 0 counts/s | DDM nodes | 1 minute |
| Writes | Write operations of the DDM instance node within a monitoring period | ≥ 0 counts/s | DDM nodes | 1 minute |
| Slow SQL Logs | Number of slow SQL queries added within a monitoring period | ≥ 0 counts | DDM nodes | 1 minute |
| Average Response Latency | Average SQL response latency of the DDM instance node | ≥ 0 ms | DDM nodes | 1 minute |
| Connections | Connections of the DDM instance node | ≥ 0 counts | DDM nodes | 1 minute |
| Tuning Backend Connections | Percentage of active connections (from a DDM node to the target RDS DB instance) in maximum backend connections | 0-100% | DDM nodes | 1 minute |
Dimensions
| Key | Value |
| ddm_node_id | DDM nodes |
