Setting a Hint to Skip the Cached Execution Plan
DDM allows you to configure a hint to control whether the SELECT statement skips the cached execution plan.
The hint is in the format of /*!GAUSS:skip_plancache=flag*/.
flag can be set to true or false. true indicates that the statement skips the cached execution plan. false indicates that the statement does not skip the cached execution plan.
Currently, this function only applies to SELECT statements.
