Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Network/ DNS/ Using CoreDNS for Custom Domain Name Resolution
Challenges
When using CCE, you may need to resolve custom internal domain names in the following scenarios:
  • In the legacy code, a fixed domain name is configured for calling other internal services. If the system decides to use Kubernetes Services, the code refactoring workload could be heavy.
  • A service is created outside the cluster. Data in the cluster needs to be sent to the service through a fixed domain name.
Solution
There are several CoreDNS-based solutions for custom domain name resolution:
Precautions
Improper modification on CoreDNS configuration may cause domain name resolution failures in the cluster. Perform tests before and after the modification.
Configuring the Stub Domain for CoreDNS
Cluster administrators can modify the ConfigMap for the CoreDNS Corefile to change how service discovery works.
Assume that a cluster administrator has a Consul DNS server located at 10.150.0.1 and all Consul domain names have the suffix .consul.local.
  2. In the navigation pane, choose Add-ons. Then, click Edit under CoreDNS.
  3. Add a stub domain in the Parameters area. The format is a key-value pair. The key is a DNS suffix domain name, and the value is a DNS IP address or a group of DNS IP addresses, for example, consul.local -- 10.150.0.1.
  4. Click OK.
  5. Choose ConfigMaps and Secrets in the navigation pane, select the kube-system namespace, and view the ConfigMap data of coredns to check whether the update is successful.
    The corresponding Corefile content is as follows:
    .:5353 {
        bind {$POD_IP}
        cache 30 {
            servfail 5s
        errors
        health {$POD_IP}:8080
        kubernetes cluster.local in-addr.arpa ip6.arpa {
            pods insecure
            fallthrough in-addr.arpa ip6.arpa
        loadbalance round_robin
        prometheus {$POD_IP}:9153
        forward . /etc/resolv.conf {
            policy random
        reload
        ready {$POD_IP}:8081
    consul.local:5353 {
        bind {$POD_IP}
        errors
        cache 30
        forward . 10.150.0.1
Modifying the CoreDNS Hosts Configuration File
After modifying the hosts file in CoreDNS, you do not need to configure the hosts file in each pod to add resolution records.
  3. Edit the advanced configuration under Parameters and add the following content to the plugins field:
      "configBlock": "192.168.1.1 www.example.com\nfallthrough",
      "name": "hosts"
    The fallthrough field must be configured. fallthrough indicates that when the domain name to be resolved cannot be found in the hosts file, the resolution task is transferred to the next CoreDNS plug-in. If fallthrough is not specified, the task ends and the domain name resolution stops. As a result, the domain name resolution in the cluster fails.
    For details about how to configure the hosts file, visit https://coredns.io/plugins/hosts/.
  4. Click OK.
    .:5353 {
        bind {$POD_IP}
        hosts {
          fallthrough
        cache 30
        errors
            pods insecure
            policy random
        reload
Adding the CoreDNS Rewrite Configuration to Point the Domain Name to Services in the Cluster
Use the Rewrite plug-in of CoreDNS to resolve a specified domain name to the domain name of a Service. For example, the request for accessing the example.com domain name is redirected to the example.default.svc.cluster.local domain name, that is, the example service in the default namespace.
       "name": "rewrite",
       "parameters": "name example.com example.default.svc.cluster.local"
  4. Click OK.
    .:5353 {
        bind {$POD_IP}
        rewrite name example.com example.default.svc.cluster.local
        cache 30
        errors
            pods insecure
            policy random
        reload
Using CoreDNS to Cascade Self-Built DNS
By default, CoreDNS uses the /etc/resolv.conf file of the node for resolution. You can also change the resolution address to that of the external DNS.
  3. Edit the advanced configuration under Parameters and modify the following content in the plugins field:
        "configBlock": "policy random",
        "name": "forward",
        "parameters": ". 192.168.1.1"
  4. Click OK.
    .:5353 {
        bind {$POD_IP}
        cache 30
        errors
            pods insecure
        forward . 192.168.1.1 {
            policy random
        reload
