- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Enhanced Hyperledger Fabric BCS Management
- Best Practices
Developer Guide
- Overview
- Chaincode Development
- Application Development
- Demos
Blockchain Middleware APIs
- Overview
- Chaincode Invoking (OBT)
Chaincode Management
- Obtaining a Token
- Installing a Chaincode
- Instantiating a Chaincode
- Listing Installed Chaincodes
- Querying Version of a Specified Chaincode
- Querying Chaincode Installation Information
- Querying Chaincode Instantiation Information
- Querying an Appchain
- Listing Blocks
- Listing Transactions
- Querying Transaction Quantity
- Listing Block Transactions
- Querying Transaction Details
- Querying Peers
- Querying diskUsage of a Node
- Querying the System-Hosted Certificate Status
- Deleting a Chaincode
- Downloading a Report
- Distributed Identity (OBT)
- Trusted Data Exchange (OBT)
- Appendix
API Reference
- Before You Start
- API Overview
- Examples
- Calling APIs
APIs (Enhanced Hyperledger Fabric)
BCS Management
- Creating a BCS Service
- Querying Creation Status of a BCS Service
- Querying a BCS Service
- Modifying a BCS Service
- Creating Channels
- Querying Channel Information
- Adding Peers to a Channel
- Removing Organizations from a Channel
- Downloading Certificates
- Downloading the SDK Configuration
- Generating a User Certificate
- Unfreezing a User Certificate
- Freezing a User Certificate
- Querying Quotas
- Querying Flavors
- Querying Peer Information
- Querying Asynchronous Operation Results
- Querying the BCS Service List
- Deleting a BCS Service
- Removing a Peer from a Channel
- Deleting a Channel
- BCS Consortium
- BCS Monitoring
BCS Management
- Appendix
- Change History
- SDK Reference
- Billing
Instance Management
Consultation
- How Do I Determine Whether a Blockchain Is Necessary?
- What Underlying Framework Is Used for Huawei Cloud BCS?
- Can BCS Instances Deployed on the Public Cloud Access Blockchain Nodes on Other Clouds?
- What Competitive Advantages Does Huawei Cloud BCS Have?
- In Which Direction and What Capabilities Will Huawei Cloud BCS Develop?
- What Are the Specifications of VMs to Be Purchased for BCS?
- How Do I Get Access to the Partners of Huawei Cloud BCS for More Services?
- What Are the Differences Between Channel Isolation and Privacy Protection?
- How Well Does BCS Perform?
- Does BCS Support Customized Development?
- When Do I Need to Hibernate or Wake an Instance?
Service Usage
- Which Ports of a Security Group Are Opened When I Create a BCS Instance?
- How Do I Check Whether the ICAgent Is Installed for the Cluster?
- What Can I Do If I Can't Open the Blockchain Management Console?
- What Should I Do If My BCS Instance Remains in the Creating State?
- What Should I Do If a Peer Restarts Frequently with the Error Message "PanicDB not exist"?
- What Can I Do If the CPU Usage of a Blockchain Node Reaches 100%?
- Why Can't I Log In to the Blockchain Management Console?
- BCS.4009100: System Error
- How Can I Obtain Private Keys and Certificates for Enhanced Hyperledger Fabric Blockchains?
- Why Does Chaincode Instantiation Fail When I Deploy a Fabric v1.4 Instance Using a v1.19 CCE Cluster?
- Can All Blocks Be Saved As More and More Blocks Are Created?
What Can I Do If I Fail to Purchase a BCS Instance?
- General Checks
Detailed Checks
- CCE Cluster Quota Used Up
- Failed to Create a Cluster
- Failed to Create a PVC
- Cluster Already In Use
- SFS Turbo File System Quota Exceeded
- No EIP Bound
- CCE Is Abnormal
- Cluster Status Is Abnormal
- Subnet Unavailable
- Quick Deployment in Progress
- CCE Status Check Times Out
- Insufficient Master Nodes in the AZ of the CCE Cluster
Abnormal Instance Statuses
- What Can I Do If a BCS Instance Is in the Abnormal State?
- What Can I Do If a BCS Instance Is in the Unknown State?
- What Can I Do If a BCS Instance Is in the EIP abnormal State?
- What Can I Do If a BCS Instance Is in the Frozen or Cluster frozen State?
- What Can I Do If the BCS Instance and the peer-xxx StatefulSet Are Abnormal After an Organization or a Peer Is Added?
- Other Issues
Consultation
- Chaincode Management
- Data Storage to the Blockchain
- Demos and APIs
- O&M and Monitoring
- Consortium Management
- Videos
More Documents
- Managing Enhanced Hyperledger Fabric Instances
BCS FAQs
Instance Management
Consultation
- What Underlying Framework Is Used for BCS?
- What Competitive Advantages Does BCS Have?
- What Are the Specifications of VMs to Be Created for BCS?
Service Usage
- Abnormal Instance Statuses
- Other Issues
Consultation
- Demos and APIs
Instance Management
BCS FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Blockchain Service/
User Guide (ME-Abu Dhabi Region)/
Managing Enhanced Hyperledger Fabric Instances/
Instance Management/
O&M Center/
Viewing Chaincode Debug Logs
You can view chaincode debug logs to analyze and locate problems. This section describes how to view chaincode debug logs on the CCE console.
- Log in to the CCE console.
- In the navigation pane, choose Workloads > Deployments. Select the cluster where the BCS instance is deployed.
- Click the workload whose name starts with baas-agent.
- Click Logs in the upper right corner to view the logs of the chaincode container. To view more logs or export logs, go to the AOM console.
Figure 1 Viewing the chaincode pod logs
Parent topic: O&M Center
