Viewing O&M Logs
Introduction
If an exception occurs when you use a BCS instance, view the O&M logs to analyze and locate the fault for quick rectification. This section describes how to view the O&M logs of each BCS instance node in the CCE cluster on the frontend GUI and backend virtual machines (VMs).
Component |
Description |
Log Path |
baas-agent |
Blockchain management run log |
/var/paas/sys/log/baas-agent/baas-agent.log /var/paas/sys/log/baas-agent/audit.log |
peer |
Peer run log |
/var/paas/sys/log/baas-service/peer/audit.peer-******-*.log /var/paas/sys/log/baas-service/peer/peer-******-*.trace |
orderer |
Orderer run log |
/var/paas/sys/log/baas-service/orderer/audit.orderer-******-*.log /var/paas/sys/log/baas-service/orderer/orderer-******-*-start.trace /var/paas/sys/log/baas-service/orderer/orderer-******-*.trace |
Viewing O&M Logs on a Backend VM
- On the CCE console, view and record the node name on the Workloads page.
- On the Instance Management page of the BCS console, locate the instance and choose More > Change Access Address to view the access address.
Figure 1 Viewing the access address
The node where the BCS instance is deployed must be bound with an EIP.
- Log in to the VM corresponding to the access address, and view the O&M logs.
Figure 2 Logging to the VM
Enter the VM address (the access address obtained in 2) for Remote host, and enter the VM username for Specify username.- Check baas-agent node logs.
- Run the following command to query the baas-agent node ID:
docker ps|grep baas-agent
Figure 3 Checking the baas-agent node ID
- Run the following command to query the baas-agent node logs:
docker logs ID -f
Figure 4 Checking the baas-agent node logs
- Check the logs of a peer node.
- Run the following command to query the peer node ID:
docker ps|grep peer
Figure 5 Checking the peer ID
- Run the following command to query the peer node logs:
docker logs -f ID
Figure 6 Checking the peer logs
- Check the logs of an orderer node.
- Run the following command to query the orderer ID:
docker ps|grep orderer
Figure 7 Checking the orderer ID
- Run the following command to query the orderer logs:
docker logs -f ID
Figure 8 Checking the orderer logs
