Disk Metrics
After metric thresholds and alarming criteria related to disk usage are configured, alarming short messages or emails can be sent to technical support. In this way, technical support can detect and handle service exceptions in a timely manner to reduce the loss caused by exceptions. The following table lists the metrics related to disks used for BCS services.
Metrics |
Description |
Meaning |
Value Range |
Unit |
diskAvailableCapacity |
Available disk space |
Disk space that is not used |
≥ 0 |
MB |
diskCapacity |
Disk capacity |
Total disk capacity |
≥ 0 |
MB |
diskReadRate |
Disk read rate |
Data volume read from the disk per second |
≥ 0 |
KB/s |
diskRWStatus |
Disk read/write status |
Read/write status of the disk on a node |
0 (read and write) and 1 (read-only). |
None |
diskUsedRate |
Disk usage |
Percentage of the used disk space to the total disk space |
≥ 0 |
Percentage |
diskWriteRate |
Disk write rate |
Data volume written into the disk per second |
≥ 0 |
KB/s |
Disk metrics can be calculated on the following basis.
Basis |
Description |
clusterId |
Cluster ID |
clusterName |
Cluster name |
hostID |
Node ID |
namespace |
Cluster namespace |
nodeIP |
IP addresses of a node |
nodeName |
Node name |
