- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Enhanced Hyperledger Fabric BCS Management
- Best Practices
Developer Guide
- Overview
- Chaincode Development
- Application Development
- Demos
Blockchain Middleware APIs
- Overview
- Chaincode Invoking (OBT)
Chaincode Management
- Obtaining a Token
- Installing a Chaincode
- Instantiating a Chaincode
- Listing Installed Chaincodes
- Querying Version of a Specified Chaincode
- Querying Chaincode Installation Information
- Querying Chaincode Instantiation Information
- Querying an Appchain
- Listing Blocks
- Listing Transactions
- Querying Transaction Quantity
- Listing Block Transactions
- Querying Transaction Details
- Querying Peers
- Querying diskUsage of a Node
- Querying the System-Hosted Certificate Status
- Deleting a Chaincode
- Downloading a Report
- Distributed Identity (OBT)
- Trusted Data Exchange (OBT)
- Appendix
API Reference
- Before You Start
- API Overview
- Examples
- Calling APIs
APIs (Enhanced Hyperledger Fabric)
BCS Management
- Creating a BCS Service
- Querying Creation Status of a BCS Service
- Querying a BCS Service
- Modifying a BCS Service
- Creating Channels
- Querying Channel Information
- Adding Peers to a Channel
- Removing Organizations from a Channel
- Downloading Certificates
- Downloading the SDK Configuration
- Generating a User Certificate
- Unfreezing a User Certificate
- Freezing a User Certificate
- Querying Quotas
- Querying Flavors
- Querying Peer Information
- Querying Asynchronous Operation Results
- Querying the BCS Service List
- Deleting a BCS Service
- Removing a Peer from a Channel
- Deleting a Channel
- BCS Consortium
- BCS Monitoring
BCS Management
- Appendix
- Change History
- SDK Reference
- Billing
Instance Management
Consultation
- How Do I Determine Whether a Blockchain Is Necessary?
- What Underlying Framework Is Used for Huawei Cloud BCS?
- Can BCS Instances Deployed on the Public Cloud Access Blockchain Nodes on Other Clouds?
- What Competitive Advantages Does Huawei Cloud BCS Have?
- In Which Direction and What Capabilities Will Huawei Cloud BCS Develop?
- What Are the Specifications of VMs to Be Purchased for BCS?
- How Do I Get Access to the Partners of Huawei Cloud BCS for More Services?
- What Are the Differences Between Channel Isolation and Privacy Protection?
- How Well Does BCS Perform?
- Does BCS Support Customized Development?
- When Do I Need to Hibernate or Wake an Instance?
Service Usage
- Which Ports of a Security Group Are Opened When I Create a BCS Instance?
- How Do I Check Whether the ICAgent Is Installed for the Cluster?
- What Can I Do If I Can't Open the Blockchain Management Console?
- What Should I Do If My BCS Instance Remains in the Creating State?
- What Should I Do If a Peer Restarts Frequently with the Error Message "PanicDB not exist"?
- What Can I Do If the CPU Usage of a Blockchain Node Reaches 100%?
- Why Can't I Log In to the Blockchain Management Console?
- BCS.4009100: System Error
- How Can I Obtain Private Keys and Certificates for Enhanced Hyperledger Fabric Blockchains?
- Why Does Chaincode Instantiation Fail When I Deploy a Fabric v1.4 Instance Using a v1.19 CCE Cluster?
- Can All Blocks Be Saved As More and More Blocks Are Created?
What Can I Do If I Fail to Purchase a BCS Instance?
- General Checks
Detailed Checks
- CCE Cluster Quota Used Up
- Failed to Create a Cluster
- Failed to Create a PVC
- Cluster Already In Use
- SFS Turbo File System Quota Exceeded
- No EIP Bound
- CCE Is Abnormal
- Cluster Status Is Abnormal
- Subnet Unavailable
- Quick Deployment in Progress
- CCE Status Check Times Out
- Insufficient Master Nodes in the AZ of the CCE Cluster
Abnormal Instance Statuses
- What Can I Do If a BCS Instance Is in the Abnormal State?
- What Can I Do If a BCS Instance Is in the Unknown State?
- What Can I Do If a BCS Instance Is in the EIP abnormal State?
- What Can I Do If a BCS Instance Is in the Frozen or Cluster frozen State?
- What Can I Do If the BCS Instance and the peer-xxx StatefulSet Are Abnormal After an Organization or a Peer Is Added?
- Other Issues
Consultation
- Chaincode Management
- Data Storage to the Blockchain
- Demos and APIs
- O&M and Monitoring
- Consortium Management
- Videos
More Documents
- Managing Enhanced Hyperledger Fabric Instances
BCS FAQs
Instance Management
Consultation
- What Underlying Framework Is Used for BCS?
- What Competitive Advantages Does BCS Have?
- What Are the Specifications of VMs to Be Created for BCS?
Service Usage
- Abnormal Instance Statuses
- Other Issues
Consultation
- Demos and APIs
Instance Management
BCS FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
Supply Chain Logistics
Manufacturers, warehousing institutes, logistics providers, and customers can use BCS to comprise collaboration consortia and use IoT technologies to record all the logistics information of goods, including production, warehousing, line haul transportation, reselling, and local logistics. The consortia break down information silos, improve circulation of information, and build trust between parties.
Industry Status Quo and Pain Points
- Disadvantage of using paper documents
Many phases of logistics still involve manual operations and paper documents. This causes long duration of the process, high costs, slow reconciliation, and risks of document losses or damage. The cost on maintaining and transferring documents accounts for 1/5 of the total logistics cost.
- Low efficiency
Participants in a supply chain have their own information systems, independent from each other. There is no unified standard or system. It is difficult for them to collaborate effectively.
- Long duration
Electronic information can be easily tampered with. Therefore, paper documents are used as the only type of proof for settlement, but extend the accounting period and the carriers' average collection period of receivables.
- Difficult financing
Most carriers are small- and medium-sized enterprises, lacking credit records, scores, or credibility. Financing is difficult and requires high costs.
Solution Architecture
The supply chain logistics solution provided by BCS can be combined with the IT information systems of logistic participants to achieve the following:
- Jointly maintain unified ledgers, which store immutable and traceable goods transfer records to meet audit requirements.
- Provide common APIs for participants' IT systems to access BCS and input data, which cannot be tampered with. In this way, participants establish their credibility and trust in each other.
- Automatically store the geo-fence information reported by the driver's app to show in real time when, where, and by whom goods are processed.
- Fulfill smart contracts to automatically perform signing, settlement, and calculation to obtain the performance data, which is considered fair due to the automation.
Solution Highlights
- Reduced errors
Distributed, shared ledgers greatly improve the traceability and transparency of the supply chain and effectively reduce or eliminate changes of frauds and errors.
- Increased efficiency
Electronic proofs of delivery (PODs) are used instead of paper documents to reduce the delay caused by paper works. Smart contracts enable automatic settlement to improve efficiency.
- Lower costs
Quick settlement, automatic order reception, and goods follow-up significantly lower the logistics costs of all the involved parties.
- Transparent audit
Immutability of distributed ledgers and non-repudiation of signatures allow for quick discovery of problems in supply chain logistics.
- Trust
In addition to transparent rules and automated settlement, the blockchain technology can help you follow goods all the way through production and transport to final reception. These mechanisms greatly improve the trust between all the involved parties.
