VPC.Subnet
Element Description
The VPC.Subnet element is used to create a subnet on a VPC.
Element Properties
Property |
Mandatory |
Descripiton |
dnsList |
No |
IP address set of the DNS server on the subnet. Set this field if you want to use more than two DNS servers. Type: ip array Value Description: It must be an IP address array, for example, ["8.8.8.8", "4.4.4.4", "6.6.6.6"]. Value Constraint: The value must be an IP address array and contain the values of primaryDns and secondaryDns. Suggestion: If a DNS server is needed in a subnet, set at least one of the primaryDns and dnsLists parameters. If primaryDns, secondaryDns and dnsLists are not set, the created subnet will not have a DNS server. |
vpcId |
Yes |
ID of the VPC to which the subnet belongs Type: Cloud.VPC.VPC.Id Value Description: Use the ID of an existing VPC or a new VPC. To use a new VPC ID, you need to define the VPC object in the template and establish the dependency. You are advised to drag the object to the VPC to automatically establish the dependency. Value Constraint: The value must be in the CIDR format, for example, 192.168.0.0/16. Suggestion: 1. You are advised to use the get_input function to set values so that you can select an existing VPC when creating a stack. 2. To obtain the VPC information about this template, you are advised to use the get_reference function. 3. Obtain the ID of the created VPC from the VPC console. |
name |
Yes |
Subnet name Type: string Value Description: Customize the value, for example, musubnet. Default: "" Value Constraint: The value contains 1 to 64 characters. The value is unique in a VPC. Only letters, digits, underscores (_), and hyphens (-) are allowed. Suggestion: Customize the value. If this parameter is left blank, the system automatically assigns a name. |
secondaryDns |
No |
IP address 2 of the DNS server on the subnet Type: ip Value Description: It must be in the IP address format, for example, 4.4.4.4. Value Constraint: The value must be an IP address. |
gateway |
Yes |
Subnet gateway Type: ip Value Description: gateway address within the subnet CIDR address range Default: 192.168.1.1 Value Constraint: The value must be an IP address and comply with the gateway IP address rule, for example, 192.168.1.1. Suggestion: Customize the value based on the IP address range as required. |
availabilityZone |
No |
AZ to which the subnet belongs Type: Cloud.ECS.AvailabilityZone.Name Value Description: AZ where the to-be-created ECS is located. The name of the AZ needs to be specified. Value Constraint: The value varies depending on regions. Suggestion: You are advised to use the get_input function to set values so that you can select a value from the list when creating a stack. |
primaryDns |
No |
IP address 1 of the DNS server on the subnet Type: ip Value Description: It must be in the IP address format, for example, 8.8.8.8. Value Constraint: The value must be an IP address. Suggestion: If a DNS server is needed in a subnet, set at least one of the primaryDns and dnsLists parameters. If primaryDns, secondaryDns and dnsLists are not set, the created subnet will not have a DNS server. |
dhcpEnable |
Yes |
Whether to enable DHCP for the VPC subnet Type: boolean Value Description: true: Enabling the DHCP function. After an ECS using the VPC starts, the ECS automatically obtains an IP address using the DHCP protocol. false: Disabling the DHCP function. After an ECS using this VPC starts, the ECS cannot automatically obtain an IP address. You must manually assign an IP address to the ECS. Default: True Value Constraint: The value can be true or false. Suggestion: Set the value based on requirements. You are advised to enable the function. |
cidr |
Yes |
Range of available addresses in a subnet Type: string Value Description: Range: 10.0.0.0/8-10.255.255.0/24, 172.16.0.0/12-172.31.255.0/24, or 192.168.0.0/16-192.168.255.0/24. Default: 192.168.1.0/24 Value Constraint: The value must be in the CIDR format, for example, 192.168.0.0/16. The value must be within the VPC CIDR block. Suggestion: Customize the value based on the IP address range as required. |
Relationships Between Elements
Description |
Target |
ContainedIn |
Return Value
Property |
Type |
Description |
neutron_network_id |
string |
OpenStack network ID |
vpcId |
string |
ID of the VPC to which the subnet belongs |
neutron_subnet_id |
string |
OpenStack subnet ID |
refName |
string |
Subnet name |
refID |
string |
Subnet ID |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 inputs: vpc-name: default: vpc type: string vpc-cidr: default: 192.168.0.0/16 type: string subnet-name: type: string default: subnet subnet-cidr: default: 192.168.0.0/24 type: string subnet-gateway: type: ip default: 192.168.0.1 dhcenable: type: boolean default: true availabilityZone: description: Name of az label: '' node_templates: my-vpc: type: Cloud.VPC.VPC properties: name: get_input: vpc-name cidr: get_input: vpc-cidr my-subnet: type: Cloud.VPC.Subnet properties: name: get_input: subnet-name cidr: get_input: subnet-cidr gateway: get_input: subnet-gateway dhcpEnable: get_input: dhcenable dnsList: [114.114.114.115,114.114.114.114] vpcId: get_attribute: [my-vpc,refID] availabilityZone: get_input: availabilityZone requirements: - vpcId: node: my-vpc
