VPC.SecurityGroupRule
Element Description
A security group rule is an access policy added for an ECS to implement access control.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
direction
Yes
Ingress or egress control direction (that is, ingress or egress)
Type: string
Value Description: The options are egress and ingress.
Default: ingress
Value Constraint: {u'valid_values': [u'egress', u'ingress']}
protocol
No
Protocol type
Type: string
Value Description: The options are ICMP, TCP, and UDP. If this property is left blank, all protocols are supported.
Value constraint: {u'valid_values': [u'ICMP', u'TCP', u'UDP']}
remoteSecurityGroupId
No
Peer security group ID
Type: Cloud.VPC.SecurityGroup.Id
Value Description: Obtain the security group ID from the VPC service or automatically generate it through VPC.SecurityGroup.
Value Constraint: The value of this parameter and the value of remoteIpPrefix are mutually exclusive.
Suggestion: It is advised to obtain the ID of a SecurityGroup object using get_input or get_reference.
ethertype
No
Protocol type of the IP address
Type: string
Value Description: Set it to IPv4.
Default: IPv4
Value constraint: {u'valid_values': [u'IPv4']}
securityGroupId
Yes
ID of the security group the resource belongs
Value Description: Obtain the security group ID from the VPC service or connects to the VPC.SecurityGroup to automatically generate a security group ID.
Value Constraint: The value must meet the UUID generation rule and be the ID of an existing security group of the tenant.
Suggestion: You are advised to use the get_input function to obtain the value, or connect the SecurityGroup object and use the get_reference function to automatically generate the value.
remoteIpPrefix
No
Remote IP address
Type: string
Value Description: When the direction is egress, it is the address of the terminal that accesses the VM. When the direction is ingress, it is the address of the to-be-accessed VM.
Value Constraint: The value can be in the CIDR format or an IP address. The value of this parameter and the value of remoteSecurityGroup are mutually exclusive.
maxPort
No
Destination port number
Type: integer
Value Description: Customize the value. The value ranges from 1 to 65535.
Value Constraint: {u'in_range': [1, 65535]}
Suggestion: If the protocol is not ICMP, the value cannot be smaller than the value of minPort. When minPort and maxPort are left blank, all port numbers are supported.
minPort
No
Start port number
Type: integer
Suggestion: The value cannot be greater than the value of maxPort. When minPort and maxPort are left blank, all port numbers are supported.
Relationships Between Elements
Table 2 Relationship description
Target
Inclusion
VPC.SecurityGroup
Return Value
Property
Type
refName
string
Security group rule name
refID
string
Security group rule ID
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  sg-id:
    type: Cloud.VPC.SecurityGroup.Id
  direction:
    default: ingress
    type: string
  ethertype:
    default: IPv4
    type: string
  protocol:
    default: TCP
    type: string
  minPort:
    default: 80
    type: integer
  maxPort:
    default: 80
    type: integer
  remoteSecurityGroup:
node_templates:
  my-rule:
    type: Cloud.VPC.SecurityGroupRule
    properties:
      securityGroupId: {get_input: sg-id}
      direction: {get_input: direction}
      ethertype: {get_input: ethertype}
      protocol: {get_input: protocol}
      minPort: {get_input: minPort}
      maxPort: {get_input: maxPort}
      remoteSecurityGroup: {get_input: remoteSecurityGroup}
outputs:
  rule-id:
    value:
      get_attribute: [my-rule, refID]
