VPC.EIP
Element Description
VPC.EIP is used to create a public elastic IP address. A public elastic IP address is a static IP address. You can bind or unbind an elastic IP address to an Elastic Cloud Server (ECS) in a subnet. An ECS in a Virtual Private Cloud (VPC) can access the Internet through a fixed public IP address.
Element Properties
        Property  |
        Mandatory  |
        Description  |
        publicIP  |
        Yes  |
        Elastic IP address object Type: VPC.PublicIP Default value: {u'type': u'unset'}  |
        instances  |
        No  |
        Number of elastic IP addresses Type: integer Value Description: Customize the value. The default value is 1. Default Value: 1 Constraint: {u'greater_or_equal': 1}  |
        bandwidth  |
        Yes  |
        Bandwidth object Type: VPC.BandWidth Default value: {u'shareType': u'PER'}  |
Relationships Between Elements
        Description  |
        Target  |
        Dependency  |
        Dependency  |
Return Value
        Property  |
        Type  |
        Description  |
        refIP  |
        string  |
        Elastic IP address created  |
        idList  |
        string  |
        ID of the elastic IP addresses created in batch  |
        refID  |
        string  |
        ID of the elastic IP address.  |
        ipList  |
        string  |
        Elastic IP addresses created in batch  |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  publicip-type:
    default: 5_bgp
    description: Public IP type.
  size:
    default: 1
    description: bandwidth size
node_templates:
  eip:
    properties:
      bandwidth:
        shareType: PER
        size:
          get_input: size
      publicIP:
        type:
          get_input: publicip-type
    type: Cloud.VPC.EIP
