ULB.Pool
Element Description
For ECS groups under a shared load balancer, one listener corresponds to multiple ECS groups. You can add or delete ECS groups as required. An ECS group consists of multiple ECSs.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
sessionPersistence
No
Session persistence setting
Type: ULB.StickySession
Value Description: If this option is selected, the session persistence function is enabled by default.
Default: {u'type': u'SOURCE_IP'}
Suggestion: Set the value based on the live environment.
protocol
Yes
ECS group protocol
Type: string
Value Description: The options are HTTP and TCP.
Value Constraint: The value must be consistent with the listener protocol.
name
No
ECS group name
Type: string
Value Description: Customize the value.
Value Constraint: The value supports a maximum of 64 characters and can only contain digits, letters, underscores (_), and hyphens (-).
Suggestion: Customize the value.
lbAlgorithm
Yes
Allocation policy type
Type: string
Value Description: ROUND_ROBIN: indicates the weighted round robin algorithm. LEAST_CONNECTIONS: indicates the weighted least connection. SOURCE_IP: indicates the source IP algorithm.
Default: ROUND_ROBIN
Value Constraint: The options are ROUND_ROBIN, LEAST_CONNECTIONS, and SOURCE_IP.
listenerId
Yes
ID of the belonged listener
Type: string
Value Description: ID generated after a ULB instance is created, for example, 8abbd7a9-c1f8-440d-96ff-376ee7382082.
Value Constraint: The ID must be the listener ID of an existing ULB instance.
Suggestion: You are advised to drag the object to the ULB.Listener and use the get_reference function to automatically generate the value. Alternatively, obtain the ULB listener ID on the ULB console and enter it accordingly.
Relationships Between Elements
Table 2 Relationship description
Target
Inclusion
ULB.Listener
Return Value
Property
Type
refID
string
ECS group instance ID
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  pool_protocol:
     description: ECS group protocol, which must be consistent with the listener protocol
  pool_listenerId:
     description: Belonged listener ID
  pool_lbAlgorithm:
     description: Allocation policy type
node_templates:
  pool:
    type: Cloud.ULB.Pool
    properties:
      protocol:
        get_input: pool_protocol
      listenerId:
        get_input: pool_listenerId
      lbAlgorithm:
        get_input: pool_lbAlgorithm
