- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
ULB.LoadBalancer
Element Description
The ULB.LoadBalancer element can be used to deploy a shared load balancer resource object at the PaaS layer. By creating such an object, you can provide a unified entry address for a group of containerized applications with the same functions, and distribute requests in load balancing mode to backend container applications. Shared load balancers are applicable to web services with high access traffic. They forward requests based on domain names or URLs, making request routing more flexible. Compared with classic load balancers, shared load balancers provide stronger HTTP and HTTPS forwarding capabilities, and better forwarding performance and stability.
Element Properties
Property |
Mandatory |
Descripiton |
vipAddress |
No |
IP address of the VPC where the shared load balancer is located Type: ip Value Description: IP address that is not used in the selected subnet Value Constraint: The value must be an IP address. |
description |
No |
Description Type: string Value Description: Customize the value. Value Constraint: The value supports a maximum of 255 characters. Suggestion: Customize the value. |
publicIpId |
No |
ID of the elastic IP address that can be bound to the shared load balancer Type: string Value Description: ID of the elastic IP address that can be bound to the VPC. Suggestion: Query the binding status and ID of the elastic IP address on the elastic IP address page of the VPC service. |
subnetId |
Yes |
ID of the subnet that allocates VIP addresses to the shared load balancer Type: Cloud.VPC.Subnet.All.Id Value Description: ID of the subnet of the VPC Value Constraint: You can view the subnet ID in the VPC details page. Suggestion: Drag the object to VPC.Subnet and use {get_attribute: [element name, neutron_subnet_id]} to automatically generate the value. |
name |
No |
Name of the shared load balancer Type: string Value Description: Customize the value. Value Constraint: The value supports a maximum of 64 characters and can only contain digits, letters, underscores (_), and hyphens (-). Suggestion: Customize the value. |
Relationships Between Elements
Description |
Target |
Connected |
Connected |
Return Value
Property |
Type |
Description |
vip_port_id |
string |
PORT_ID of the VPC where the shared load balancer is located |
refName |
string |
Name of the shared load balancer |
refID |
string |
ID of the shared load balancer |
vip_address |
string |
IP address of the VPC where the shared load balancer is located |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 inputs: subnetId: description: ID of the subnet that allocates VIP addresses to the shared load balancer. It is the subnet ID rather than the subnet network ID. node_templates: ulb: properties: description: ulb load balancer subnetId: get_input: subnetId type: Cloud.ULB.LoadBalancer
