ULB.Listener
Element Description
The ULB.Listener element indicates the listener under a shared load balancer. One shared load balancer corresponds to multiple listeners. You can add or delete listeners as required.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
protocol
Yes
Listening protocol
Type: string
Value Description: This value can be TCP or HTTP.
Value Constraint: This value can be TCP or HTTP.
Suggestion: Set the value based on the live environment.
description
No
Type: string
Value Description: Customize the value.
Value Constraint: The value supports a maximum of 255 characters.
Suggestion: Customize the value.
connectionLimit
No
Maximum number of connections of the listener
Type: integer
Value Description: If the number of connections is -1, there is no constraints.
Value Constraint: The value ranges from -1 to 2147483647.
loadBalancerId
Yes
ID of the belonged ULB
Type: string
Value Description: ID generated after a ULB instance is created, for example, 8abbd7a9-c1f8-440d-96ff-376ee7382082.
Value Constraint: The ID must be the ID of an existing ULB instance.
Suggestion: You are advised to drag the object to the ULB.LoadBalancer and use the get_reference function to automatically generate the value. Alternatively, obtain the ULB instance ID on the ULB console and enter it accordingly.
port
Yes
Listening port
Type: integer
Value Description: The value ranges from 1 to 65535.
Value Constraint: The value ranges from 1 to 65535.
name
No
Listener name
Type: string
Value Constraint: The value supports a maximum of 64 characters and can only contain digits, letters, underscores (_), and hyphens (-).
Relationships Between Elements
Table 2 Relationship description
Target
Inclusion
ULB.LoadBalancer
Return Value
Property
Type
refName
string
Listener instance name
refID
string
Listener instance ID
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  listener_protocol:
     description: Listening protocol
    label: ''
  listener_port:
     description: Listening port
    label: ''
  listener_loadBalancerId:
     description: ID of the belonged ULB
    label: ''
node_templates:
  listener:
    type: Cloud.ULB.Listener
    properties:
      protocol:
        get_input: listener_protocol
      port:
        get_input: listener_port
      loadBalancerId:
        get_input: listener_loadBalancerId
