ULB.Healthmonitor
Element Description
The ULB.Healthmonitor element is a health check component of a shared load balancer. One pool corresponds to one health monitor. One health monitor can manage multiple ECSs. You can add or delete health monitors as required.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
monitorPort
No
Health check port
Type: integer
Value Description: Customize the value. The value is an integer between 1 and 65535, for example, 8089. If this parameter is left blank, the backend port of the ECS is used by default.
Value Constraint: The value ranges from 1 to 65535.
Suggestion: Set the value based on the live environment.
name
No
Name of a health check job
Type: string
Value Constraint: The value supports a maximum of 64 characters and can only contain digits, letters, underscores (_), and hyphens (-).
Suggestion: Customize the value.
urlPath
No
URI for health check. This parameter is valid when type is set to HTTP. You are advised to perform check on the static page.
Type: string
Value Description: Customize the value, for example, / or /index.html.
Value Constraint: The value contains 1 to 80 characters and must start with a slash (/). Only letters, digits, and special characters -/.%?#&_= are allowed. It must meet regular expression ^/[0-9a-zA-Z-_?/.?#&=]*.
delay
Yes
Interval for health check (unit: s)
Type: integer
Value Description: Customize the value. The value is an integer ranging from 0 to 2147483647, for example, 5.
Default: 5
Value Constraint: The value is an integer ranging from 0 to 2147483647.
httpMethod
No
HTTP method for health check. This parameter is valid when type is set to HTTP.
Type: string
Value Description: The options are GET, HEAD, POST, PUT, DELETE, TRACE, OPTIONS, CONNECT, and PATCH.
Value Constraint: The options are GET, HEAD, POST, PUT, DELETE, TRACE, OPTIONS, CONNECT, and PATCH.
timeout
Yes
Maximum timeout duration for health check (unit: s)
Type: integer
Value Description: Customize the value. The value is an integer ranging from 0 to 2147483647, for example, 10.
Default: 10
poolId
Yes
ECS group ID
Type: string
Value Description: ECS group ID
Suggestion: Use the get_reference function to automatically generate the value.
maxRetries
Yes
The number of consecutive times a cloud server fails or passes health checks, after which the health check status of the backend cloud server changes from success to fail or from fail to success, respectively.
Type: integer
Value Description: Customize the value. The value is an integer between 1 and 10, for example, 3.
Default: 3
Value Constraint: The value is an integer between 1 and 10.
expectedCode
No
HTTP status code used to determine the health status of a backend ECS. This parameter is valid when type is set to HTTP.
Type: string
Value Description: Customize the value, for example, 200.
Value Constraint: The value ranges from 1 to 250.
type
Yes
Health check protocol
Type: string
Value Description: The options are HTTP, TCP, HTTPS, PING, and TLS-HELLO.
Value Constraint: The options are HTTP, TCP, HTTPS, PING, and TLS-HELLO.
Relationships Between Elements
Table 2 Relationship description
Target
Inclusion
ULB.Pool
Return Value
Property
Type
refID
string
ID of a health check instance
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  pool_protocol:
    description: 'Cloud server group protocol. It must be the same as the listener protocol.'
  pool_listenerId:
    description: ID of the listener to which it belongs
  pool_lbAlgorithm:
    description: Allocation policy type
  delay:
    description: Interval for health check (unit: s)
  timeout:
    description: Maximum timeout duration for health check (unit: s)
  max_retries:
    description: The number of consecutive times a cloud server fails or passes health checks, after which the health check status of the backend cloud server changes from success to fail or from fail to success, respectively.
  type:
    description: Health check protocol
node_templates:
  pool:
    type: Cloud.ULB.Pool
    properties:
      protocol:
        get_input: pool_protocol
      listenerId:
        get_input: pool_listenerId
      lbAlgorithm:
        get_input: pool_lbAlgorithm
  health-monitor:
    type: Cloud.ULB.Healthmonitor
    properties:
      delay:
        get_input: delay
      timeout:
        get_input: timeout
      maxRetries:
        get_input: max_retries
      type:
        get_input: type
      poolId:
        get_reference: pool
    requirements:
      - poolId:
          node: pool
