- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
SFS.FileSystem
Element Description
SFS provides high-performance file storage which supports on-demand scaling. It can be shared by multiple ECSs.
Element Properties
Property |
Mandatory |
Descripiton |
size |
Yes |
Storage space size (unit: GB). The minimum value is 1 and the maximum value is 511800. Type: integer Value Description: The value ranges from 1 to 511800. Default: 1 Value Constraint: [1, 511800] |
vpcId |
Yes |
ID of the belonged VPC. Only ECSs in the VPC can access the SFS file system. Type: Cloud.VPC.VPC.Id Value Description: Use the ID of an existing VPC or a new VPC. Value Constraint: The value must satisfy the UUID generation rule. Suggestion: 1. Use the get_input function to set this field, and then the value can be automatically selected on the AOS console. 2. Obtain the ID of the created VPC from the VPC console. |
description |
Yes |
Shared description Type: string Value Description: Customize the value. Default: "" Value Constraint: [0, 255] |
name |
Yes |
SFS instance name Type: string Value Description: Customize the value. Default: "" Value Constraint: [0, 255] |
availabilityZone |
Yes |
AZ to which the file system belongs Type: Cloud.ECS.AvailabilityZone.Name Value Description: AZ where the to-be-shared file system is located. The name of the AZ needs to be specified. Value Constraint: The value varies depending on regions. |
accessLevel |
Yes |
Permission level of the shared access Type: string Value Description: Customize the value. Default: rw Value Constraint: The options are ro and rw. ro indicates read-only, and rw indicates read and write. |
Relationships Between Elements
Description |
Target |
Inclusion |
Return Value
Property |
Type |
Description |
ShareAccessId |
string |
UUID of a share access rule |
export_location |
string |
Sharing path |
refID |
string |
SFS ID |
export_locations |
string |
Sharing path |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 inputs: name: default: my-sfs availabilityZone: type: Cloud.ECS.AvailabilityZone.Name vpcId: type: Cloud.VPC.VPC.Id accessLevel: default: "ro" size: default: 10 node_templates: my-sfs: type: Cloud.SFS.FileSystem properties: name: {get_input: name} size: {get_input: size} availabilityZone: {get_input: availabilityZone} accessLevel: {get_input: accessLevel} vpcId: {get_input: vpcId}
