ECS.PublicIP
Property Description
        Property  |
        Mandatory  |
        Type  |
        Description  |
        eip  |
        No  |
        Configuration parameter for creating an elastic IP address that will be automatically assigned to the ECS Value Description: ECS.EIP type. Value Constraint: The value must meet the ECS.EIP type.  |
        id  |
        No  |
        string  |
        ID of the existing elastic IP address assigned to the to-be-created ECS Value Description: It must be in the UUID format. Only elastic IP addresses in the DOWN state can be assigned. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters.  |
   You can configure either but not both of id and eip in the publicip field.
