CCE.NodePool
Property Description
        Property  |
        Mandatory  |
        Type  |
        Description  |
        dataVolumes  |
        Yes  |
        Data disk of the created node Value Description: Customize the value, for example, [{"volumeType":"SATA","size":100}]. Value Constraint: Array format. Currently, only one object is supported. Suggestion: Customize the value.  |
        availabilityZone  |
        Yes  |
        Cloud.ECS.AvailabilityZone.Name  |
        AZ where the node is located Value Description: AZ where the to-be-created ECS is located. The name of the AZ needs to be specified, for example, ae-ad-1a. For details, see the Regions and Endpoints page. Value Constraint: Select a value based on the region. Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console.  |
        name  |
        No  |
        string  |
        Name of the created node Value Description: Customize the value. Value Constraint: The value contains 4 to 32 characters and must start with a lowercase letter. Only lowercase letters, digits, and underscores (_) are allowed. Suggestion: Customize the value. Generally, the stack name is used as the node name.  |
        publicKey  |
        No  |
        Cloud.ECS.KeyPair.PublicKey  |
        Public key of the key pair when the stack is billed in the yearly/monthly mode Value Description: Selects an existing public key. Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console based on the value of sshKeyName.  |
        postInstall  |
        No  |
        string  |
        Node post-installation script Value Description: Customize the value. Value Constraint: The script you specify here will be executed after K8S software is installed Suggestion: The script is usually used to modify Docker parameters.  |
        labels  |
        No  |
        dict  |
        labels of the created node Value Description: Customize the value, for example, {"key": "aos","value": "app","scope":[1,2]}. Suggestion: Enter the key, value, and scope as required.  |
        preInstall  |
        No  |
        string  |
        Node pre-installation script Value Description: Customize the value. Value Constraint: The script you specify here will be executed before K8S software is installed. Note that if the script is incorrect, K8S software may not be installed successfully. Suggestion: The script is usually used to format data disks.  |
        publicIp  |
        No  |
        Virtual IP address of the created node Value Description: Customize the value, for example, {"eip":{"bandwidth:{" shareType":PER}, 5_sbgp"}}. Value Constraint: Only one elastic IP address can be defined for each node. Suggestion: Customize the value.  |
        instances  |
        Yes  |
        integer  |
        Number of created nodes Value Description: Customize the value. The value ranges from 1 to 50. Value Constraint: {u'in_range': [1, 50]} Suggestion: Set the value based on specifications and requirements.  |
        rootVolume  |
        Yes  |
        System disk of the created node Value Description: Customize the value, for example, {"volumeType":"SATA","size":40}. Suggestion: Customize the value.  |
        os  |
        No  |
        string  |
        os of the created node Value Description: ["EulerOS 2.2", "CentOS 7.4"] Value Constraint: Customize the value. If this parameter is left blank, EulerOS 2.2 is used by default. Suggestion: The options are EulerOS 2.2 and CentOS 7.4.  |
        nodePasswd  |
        No  |
        password  |
        Password of the node root user Value Description: Customize the value. Value Constraint: 1. The parameter must be written into inputs and set using the get_input function. 2. The value must not be left blank or is a weak password. Enter 8 to 26 characters. Only uppercase and lowercase letters, digits, and special characters !@$%^-_=+[{}]:,./? are allowed. The value must contain at least two types of characters. 3. sshkeyName and nodePasswd cannot be used at the same time. Suggestion: You are advised to use the get_input function to obtain the value and avoid plaintext passwords to ensure security.  |
        flavor  |
        Yes  |
        Cloud.CCE.Node.Flavor.Name  |
        Container node specification Value Description: ID of the system flavor of the ECS to be created. You are advised to set this parameter in get_input mode. Suggestion: Select the node specification during node creation on the CCE console. In the node template, you can set the inputs to specify the node specification.  |
        sshKeyName  |
        Yes  |
        Cloud.ECS.KeyPair.Name  |
        Key pair used for logging in to a node, which needs to be kept properly Value Description: It must be created on the ECS console in advance. Value Constraint: sshkeyName and nodePasswd cannot be used at the same time. Suggestion: 1. You are advised to use the get_input function to assign values so that you can select a value when using the template. 2. Obtain the information on the ECS console and then enter the information accordingly.  |
        annotations  |
        No  |
        dict  |
        Annotations of Node Value Description: Customize the value, for example, {"app": "aos"}. Suggestion: You can enter multiple key-value pairs.  |
