CCE.DataVolume
Property Description
Property |
Mandatory |
Type |
Description |
multiAttach |
No |
boolean |
Information about the shared disk Value Description: true: shared EVS disk. false: common EVS disk. Value Constraint: The value can be true or false. Suggestion: Set the value based on the live environment. |
volumeType |
Yes |
Cloud.EVS.Volume.Type.Name |
Data disk type corresponding to the ECS. The data disk type must match the disk type provided by the system. Value Description: Data disk type corresponding to the ECS. The data disk type must match the disk type provided by the system. Constraints: The options are SATA, SAS, SSD, co-p1, and uh-l1. SATA: common I/O disk type; SAS: high I/O disk type; SSD: ultra-high I/O disk type; co-p1: high I/O (performance-optimized I); uh-l1: ultra-high I/O (latency-optimized) Suggestion: Set the value based on the live environment. |
hw:passthrough |
No |
string |
Data disk type Value Description: true: SCSI type. If this field does not exist, the VBD type is used by default. Value Constraint: This parameter can be set only to true or left blank. Suggestion: Set the value based on the live environment. |
size |
Yes |
integer |
Data disk size Value Description: data disk size (unit: GB) Value Constraint: [10, 32768] Suggestion: Set the value based on the live environment. |
