CCE.Cluster
Element Description
The CCE.Cluster element is used to deploy Kubernetes cluster resources at the PaaS layer. A master node can be created based on this element to manage and create worker nodes. This element provides the application orchestration function for users.
Element Properties
Table 1 Property Description
Property
Mandatory
multiAZ
No
Multi-AZ cluster
Type: boolean
Default: False
Value Constraint: Only when HA clusters are used, for example, clusters of cce.s2 specifications, can you set this parameter to true.
Suggestion: If multiAZ is set to true, the cluster flavor must support multi-AZ cluster creation, for example, flavors of cce.s2 specifications.
vpcId
Yes
VPC ID
Type: Cloud.VPC.VPC.Id
Value Constraint: An existing or new VPC ID can be used. To use a new VPC ID, you need to define the VPC object in the template and establish the dependency.
Suggestion: 1. Use the get_input function to set this field, and then the value can be automatically selected on the AOS console. 2. Use the get_reference function to obtain the VPC.VPC element created by the stack. 3. Obtain the ID of the created VPC from the VPC console.
networkMode
No
Container network type
Type: string
Default: overlay_l2
Value Constraint: Currently, overlay_l2, underlay_ipvlan, and vpc-router are supported. If you set it to vpc-router, the selected VPC can contain only one subnet.
Suggestion: Use the default value.
description
No
Cluster description
Type: string
Suggestion: Customize the value.
name
No
Cluster name
Type: string
Value Constraint: Enter 4 to 128 characters, starting with a letter and ending with a letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed. The value must meet regular expression (^$)|(^[a-z]([-a-z0-9]*[a-z0-9])?$).
kubeProxyMode
No
Service forwarding mode
Type: string
Default: iptables
Value Constraint: Currently, only iptables and ipvs are supported.
Suggestion: You are advised to use the default value iptables for cluster 1.7, and ipvs for cluster 1.9 and later to achieve better performance.
highwaySubnetId
No
High-speed subnet ID
Type: Cloud.VPC.Subnet.Id
Value Constraint: An existing or new subnet ID can be used. To use a new subnet ID, you need to define the subnet object in the template and establish the dependency.
Suggestion: 1. Use the get_input function to set this field, and then the value can be automatically selected on the AOS console. 2. Use the get_reference function to obtain the VPC.Subnet element created by the stack. 3. Obtain the ID of the created subnet from the VPC console.
containerNetworkCIDR
No
Container network segment
Type: string
Default: ""
Value Constraint: Set this parameter based on the live environment. The available network segments are 172.16.0.0/16-172.31.0.0/16, 10.0.0.0/16-10.255.0.0.0/16, and 192.168.0.0/16.
version
No
Cluster version
Type: string
Value Constraint: Currently, v1.15, v1.13 and v1.11 are supported.
Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console.
namespaces
No
Namespace created during cluster creation
Type: string array
Default: []
Value Constraint: array
subnetId
Yes
Subnet ID
flavor
Yes
Cluster specifications
Type: Cloud.CCE.Cluster.Flavor.Name
Value Constraint: The value must comply with CCE specifications definitions. You can view supported specifications on the CCE console.
Suggestion: You can view the names of the available cluster specifications on the cluster creation page of the CCE console.
type
No
Cluster type
Type: Cloud.CCE.Cluster.Type
Default: VirtualMachine
Value Constraint: Currently, VirtualMachine, BareMetal, Windows, and ARM64 are supported.
nodes
No
User node configuration during yearly/monthly-billed cluster creation
Type: CCE.NodePool
Default: {u'dataVolumes': [], u'availabilityZone': u'unset', u'instances': 1, u'rootVolume': {u'volumeType': u'unset', u'size': 40}, u'flavor': u'unset', u'sshKeyName': u'unset'}
Value Constraint: The value of this parameter must comply with the description and constraint of Cloud.CCE.NodePool.
Suggestion: Set the value based on the live environment.
availabilityZone
No
AZ. For clusters billed in the yearly/monthly mode, this field is mandatory.
Type: Cloud.ECS.AvailabilityZone.Name
Value Constraint: The value varies depending on regions.
Relationships Between Elements
Table 2 Relationship description
Target
Connected
VPC.Subnet
Inclusion
VPC.VPC
Return Value
Property
Type
refName
string
Cluster name
refID
string
Cluster ID
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  availabilityZone:
    default: az1.dc1
  vpcId:
    default: ba6e4347-99d2-4649-b114-85c28d3d71b0
  subnetId:
    default: 3be61f68-9bfc-41bf-8f5e-66c57122f270
  clusterFlavor:
    default: cce.s1.small
node_templates:
  cluster:
    type: Cloud.CCE.Cluster
    properties:
      availabilityZone: {get_input: availabilityZone}
      vpcId: {get_input: vpcId}
      subnetId: {get_input: subnetId}
      flavor: {get_input: clusterFlavor}
outputs:
  cluster_id:
    value: {get_attribute: [cluster, clusterId]}
