CCE.Addon.AutoScaler
Element Description
CCE.Addon.AutoScaler is a plug-in for node auto-scaling in a K8S cluster.
Element Properties
Property |
Mandatory |
Descripiton |
scaleDownUtilizationThreshold |
No |
Node resource usage ratio Type: float Value Description: The value ranges from 0 to 1. Default: 0.4 Value Constraint: The value ranges from 0 to 1. Suggestion: Set this parameter based on the live environment. |
clusterId |
Yes |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: Indicates the ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. |
scaleDownEnabled |
Yes |
Scale down function switch Type: boolean Default: False |
publicKey |
No |
Public key. This parameter is mandatory if the stack is billed in the yearly/monthly mode. Type: Cloud.ECS.KeyPair.PublicKey |
nodePasswd |
No |
Password of the scaled node root user Type: password |
nodes |
Yes |
AZs, specifications, OSs, and taints of the scaled nodes Type: CCE.Addon.AutoScaler.Node array Suggestion: In node scaling, taints are an array consisting of key, value, and effect. The effect can be set to NoSchedule, PreferNoSchedule, or NoExecute. |
sshKeyName |
No |
Node key pair Type: Cloud.ECS.KeyPair.Name |
scaleDownUnneededTime |
No |
When a node remains idle for this specified time duration (in minutes), scaling down will be performed. Type: integer Value Description: The value ranges from 1 to 1000. Default: 10 Value Constraint: The value ranges from 1 to 1000. Suggestion: Set this parameter based on the live environment. |
Relationships Between Elements
Description |
Target |
Dependency |
Inclusion |
Return Value
Property |
Type |
Description |
clusterId |
string |
ID of the cluster which is associated with the AutoScaler |
refName |
string |
Name of the AutoScaler |
refID |
string |
UID of the AutoScaler |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
clusterId:
default: "e0f98d46-9716-11e8-a25f-0255ac106314"
description: cluster ID.
nodePasswd:
default: "******"
description: node root user password
scaleDownEnabled:
default: true
description: scale down enabled.
scaleDownUnneededTime:
default: 10
description: sale down unneeded time
scaleDownUtilizationThreshold:
default: 0.5
description: scale down utilization threshold
avaliableZone:
default: az1.dc1
description: avaliableZone.
nodeFlavor:
default: s1.xlarge
description: node flavor.
nodeOS:
default: EulerOS 2.2
description: node OS.
node_templates:
autoscaler:
type: Cloud.CCE.Addon.AutoScaler
properties:
clusterId:
get_input: clusterId
nodePasswd:
get_input: nodePasswd
scaleDownEnabled:
get_input: scaleDownEnabled
get_input: scaleDownUnneededTime
get_input: scaleDownUtilizationThreshold
nodes:
- az:
get_input: avaliableZone
flavor:
get_input: nodeFlavor
os:
get_input: nodeOS
outputs:
autoscaler_id:
value: {get_attribute: [autoscaler, refID]}
