- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Show all
What Is a Template?
A template is a text file that complies with AOS syntax. It defines application attributes, cloud service configurations, and dependencies between applications and cloud services. Like code, templates can be managed by users. Code management tools such as Git and SVN can also be used to manage templates of different versions. Using templates to manage applications and cloud services simplifies the design of deploying application systems on the cloud and facilitates replicating and setting up development, testing, and production environments. This makes application systems configurable, evolvable, and traceable.
