- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Show all
mappings
The mappings section is optional and defines a mapping table. When creating a stack based on a template, you can use the get_in_map function to extract the content corresponding to a specific variable. A maximum of 10 mappings can be defined in a template.
Format of the mappings section:
<Mapping name>: <Mapping object name>: <Mapping object property name>: <Mapping object property value> <Mapping object property name>: <Mapping object property value> ... ... ...
Property |
Mandatory |
Type |
Value Constraint |
Description |
Mapping name |
Yes |
String |
The value must be 1 to 64 characters long. Only letters, digits, and hyphens (-) are allowed. |
A maximum of 10 mapping names can be defined and each name must be unique. |
Mapping object name |
Yes |
String |
Name of a mapping object, which must be unique. |
Mapping object property name |
Yes |
String |
Property name of a mapping object. Each name must be unique in the same mapping object. |
Mapping object property value |
Yes |
String or digit |
String or digit |
Property value corresponding to a mapping object. |
Example configuration of mappings:
mappings: imageMap: old: image: '192.168.1.86:20202/test/mysql-server:5.6.35' new: image: '192.168.1.90:20202/test/mysql-server:5.7.1'
Usage mode of mappings:
The defined mappings can be used in node_templates or outputs.
- Use the get_in_map function to extract the mapping content from node_templates.
For example, the myecs object is defined in node_templates, and its properties include the image ID and VM specifications. The image ID and VM specifications must have been predefined in mappings. During stack creation based on the template, the required image and VM specifications of the corresponding region will be used.
node_templates: myecs: type: Cloud.ECS.CloudServer properties: availabilityZone: ae-ad-1a flavor: get_in_map: - regionMap - get_input: Cloud.Region - flavor imageId: get_in_map: - regionMap - get_input: Cloud.Region - image_id ...
- Use the get_in_map function to extract the mapping content from outputs.
outputs: south-flavor: description: specifications of the VM to be created value: get_in_map: - regionMap - ae-ad-1 - flavor
