- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Show all
conditions
The conditions section is optional and defines conditions. By specifying conditions, you can determine whether to create and deploy elements defined in node_templates.
Format of the conditions section:
<Condition name>: <Built-in condition function> ...
The following shows how to specify conditions to control the effectiveness of properties in node_templates:
node_templates: <Element name>: condition: <Condition name> ...
Property |
Mandatory |
Type |
Value Constraint |
Description |
Condition name |
Yes |
String |
The value must be 1 to 64 characters long. Only letters, digits, and hyphens (-) are allowed. |
Name of the condition, which must be unique. |
Built-in function |
Yes |
Built-in condition functions are used to define conditions. For details, see Condition Function. |
Element name |
Yes |
String |
The value must be 1 to 48 characters long. Only lowercase letters, digits, and hyphens (-) are allowed. |
Name of the element, which must be unique. |
Condition name |
Yes |
String |
Condition name defined in conditions. |
Example configuration of conditions:
When specifying conditions to determine whether to create and deploy elements, you need to define reference relationships in multiple sections such as inputs, conditions, and node_templates.
tosca_definitions_version: cloud_tosca_version_1_0 conditions: condition_vm_deploy: #The conditions can be met only when inputs parameters are matched. cond_eq: - get_input: vm_deploy - true inputs: image: description: ID of the image used by the ECS type: Cloud.ECS.Image.Id instance: default: 1 description: number of ECSs to be created subnet: description: ID of the subnet to which the ECS belongs ..vm_deploy: #Determines whether to deploy the VM. default: true type: boolean vpc: description: ID of the VPC to which the ECS belongs node_templates: vm: condition: condition_vm_deploy # The VM will be deployed only when the conditions are met. type: Cloud.ECS.CloudServer properties: availabilityZone: ae-ad-1a imageId: get_input: image flavor: s3.small.1 instances: get_input: instance name: my-ecs nics: - subnetId: get_input: subnet rootVolume: size: 40 volumeType: SATA vpcId: get_input: vpc myecs: type: Cloud.ECS.CloudServer properties: name: my-ecs instances: get_input: instance imageId: get_input: image flavor: s3.small.1 vpcId: get_input: vpc availabilityZone: ae-ad-1a nics: - subnetId: get_input: subnet rootVolume: volumeType: SSD size: 40
