Condition Function
Condition functions are usually used to define whether elements need to be deployed, including cond_eq, cond_not, cond_and, cond_or, and cond_if. Except cond_if, other condition functions can only be used in the conditions section. The cond_if function can be used in the conditions, node_templates, and outputs sections.
For example, vm_deploy is used to determine whether to deploy a VM.
tosca_definitions_version: cloud_tosca_version_1_0
conditions:
  condition_vm_deploy:    #The conditions can be met only when inputs parameters are matched.
    cond_eq:
      - get_input: vm_deploy
      - true
inputs:
  image:
    description: ID of the image used by the ECS
    type: Cloud.ECS.Image.Id
  instance:
    default: 1
    description: number of ECSs to be created
  subnet:
    description: ID of the subnet to which the ECS belongs
..vm_deploy:    #Determines whether to deploy the VM.
    default: true
    type: boolean
  vpc:
    description: ID of the VPC to which the ECS belongs
node_templates:
  vm:
    condition: condition_vm_deploy     # The VM will be deployed only when the conditions are met.
    type: Cloud.ECS.CloudServer
    properties:
      availabilityZone: ae-ad-1a
      imageId:
        get_input: image
      flavor: s3.small.1
      instances:
        get_input: instance
      nics:
        - subnetId:
            get_input: subnet
      rootVolume:
        volumeType: SATA
      vpcId:
        get_input: vpc
  myecs:
    properties:
      instances:
        get_input: instance
      imageId:
        get_input: image
      flavor: s3.small.1
      vpcId:
        get_input: vpc
      nics:
        - subnetId:
            get_input: subnet
      rootVolume:
        volumeType: SSD
cond_eq
The cond_eq function is used to determine whether an equal condition is met. It is generally used to determine whether an input parameter is consistent with an expected value.
Table 1 cond_eq
Syntax
Parameter Description
Return Value
cond_eq: [cond1, cond2]
  • cond1: Condition 1, which can be a number, string, Boolean value, or variable obtained using the get_input function.
  • cond2: Condition 2, which can be a number, string, Boolean value, or variable obtained using the get_input function.
When the value of cond1 is the same as that of cond2, true is returned; otherwise, false is returned.
The following describes how to use the cond_eq function to determine whether the input parameter is consistent with an expected value:
inputs:
  a:
    type: string
    default: 10
conditions:
  matchA:
    cond_eq: [{get_input: a}, 10]
cond_not
The cond_not function is used to reverse the calculation result and is usually nested with other condition functions.
Table 2 cond_not
Syntax
Return Value
cond_not: cond
  • cond: Condition expression, which can be a Boolean value, Boolean variable obtained using the get_input function, or nested condition function such as cond_eq or cond_not.
If the calculation result of the condition expression is true, false is returned. If the result is false, true is returned.
The following describes how to use the cond_not function to determine whether the input parameter is consistent with an expected value:
inputs:
  a:
    type: boolean
    default: true
conditions:
  matchA:
    cond_not: {get_input: a}
cond_and
The cond_and function is used to check whether multiple conditions are met. This function supports 2 to 10 conditions.
Table 3 cond_and
Syntax
Return Value
cond_and: [cond1, cond2...condn]
  • cond1: Condition 1, which can be a Boolean value, Boolean variable obtained using the get_input function, or nested condition function such as cond_eq or cond_not.
  • cond2: Condition 2, which can be a Boolean value, Boolean variable obtained using the get_input function, or nested condition function such as cond_eq or cond_not.
  • condn: Condition n (3 ≤ n ≤ 10), which is optional and can be defined as required. The parameter type is the same as that of cond1 or cond2.
If all parameter conditions are met, true is returned; otherwise, false is returned.
The following describes how to use the cond_and function to check whether the combination conditions are met:
inputs:
  a:
    type: integer
    default: 10
  b:
    type: string
    default: debug
conditions:
  matchAnd:
    cond_and: [{cond_eq: [{get_input: a}, 10]}, {cond_eq: [{get_input: b}, debug]}]   # The condition of matchAnd can be met only when both conditions 1 and 2 are met.
cond_or
The cond_or function is used to determine whether any of multiple conditions is met. This function supports 2 to 10 conditions.
Table 4 cond_or
Syntax
Return Value
cond_or: [cond1, cond2...condn]
If any condition is met, true is returned. If no condition is met, false is returned.
The following describes how to use the cond_or function to check whether the combination conditions are met:
inputs:
  a:
    type: integer
    default: 10
  b:
    type: string
    default: debug
conditions:
  matchOr:
    cond_or: [{cond_eq: [{get_input: a}, 8]}, {cond_eq: [{get_input: b}, debug]}]  # The condition of matchOr can be met when either condition is met.
cond_if
The cond_if function is a triplet expression used to assign values to properties. It is generally used in the property structure of node_templates.
Table 5 cond_if
Syntax
Return Value
cond_if: [condition, value_true, value_false]
  • condition: Condition name, which must be defined in the conditions section.
  • value_true: Value assigned when a condition is met.
  • value_false: Value assigned when a condition is not met.
If the condition is met, value_true is returned. If the condition is not met, value_false is returned.
The following describes how to use the cond_if function to define property values:
inputs:
  a:
    type: integer
    default: 10
  b:
    type: string
    default: debug
conditions:
  matchOr:
node_templates:
  vm:
    properties:
      vpcId: vpc-id-123
      nics:
        - subnetId: subnet-id-123
      imageId: {cond_if: [matchOr, image-debug, image-product]}   # cond_if is used to define a condition. If the debugging mode is used, debugging images are used; otherwise, product images are used.
      instances: 1
      rootVolume:
        volumeType: SATA
      flavor: flavor-1
