- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Template Compilation Skills
Waiting for Component Start-up
Assume that the "A" (application) and "S" (service) components need to be started, "A" depends on "S", and "A" needs to connect to "S" to provide services. In the following example, "A" is Tomcat and "S" is MySQL.
During Application Orchestration Service (AOS) orchestration, "S" is first started based on the template. After "S" is started successfully (its process is started successfully, but its service function is still unavailable), "A" is then started. If "A" is connected to "S" before the "S" service function is completely started, "A" fails to be started. As a result, the entire stack fails to be started. Therefore, you may need to wait for a period of time before starting "A".
Currently, the waiting logic is not supported in the template syntax. To solve the problem, add the waiting logic to the service process.
The following is an example of waiting for a period of time before starting a component:
name: # Parameter name type: string # Parameter type description: resource name # Parameter description Task-Name: # Task name (user defined) description: sleep before business actions: poststart: # Execute scripts before startup. command: "/bin/sh, -c, sleep
Converting Numbers into Strings
In many cases, variables are defined as strings, but they sometimes need to be referenced as numbers. For example, when the port number is used as an environment variable, the value must be a string. When the port number is used as a microservice attribute, the value must be a number.
To solve the preceding problem, use either of the following methods:
- Method 1: Define two variables.
Define the PORT-i and PORT-s variables. PORT-s is a string, while PORT-i is a number. This method can directly be used to solve the preceding problem, but the effect is not ideal. Due to duplication, the maintainability and usability of the template deteriorate.
- Method 2: Use the concat built-in function.
Use the concat built-in function to combine multiple small strings into a longer and more complete string. The parameters of the concat built-in function can be any type of variable, supporting the combination of numbers and strings. Example command:
First, define variables as follows:
magento-EPORT: type: integer default: 32080
When the parameter indicates a ULR, ensure that its value is a string:
name: MAGENTO_URL value: concat: - "http://" - {get_input: magento-EIP} - ":" - {get_input: magento-EPORT} #Convert a number to a string.
When the parameter indicates a microservice attribute, ensure that its value is a number:
serviceSpec: ports: - port: {get_input: magento-container-port} nodePort: {get_input: magento-EPORT} #The value must be a number.
