On this page
concat
During template compilation, the concat function is often used. For example, you may obtain an IP address from the VM result and a listening port number from the APP result, and then print the final and intuitive HTTP access address in the output of the template.
The concat function is a built-in function and used to convert descriptions into strings and concatenate them. It can be embedded with the get_attribute and get_input functions.
In the current version, concat can only be defined in the outputs section. It cannot be defined in the node_templates section or embedded with the get_attribute function.
Syntax
concat: [args, {get_attribute:[...]}, {get_input: [...]} ]
Parameters
Table 1 Parameters
args
Any user-defined field. The value can be an integer, Boolean value, or string.
Example:
concat: ["string example", 100, -10, true, false], {get_attribute: [...]}, {get_input: [...]}
There is no sequence requirement for the preceding three parameters.
Return Value
Strings that are successfully concatenated are returned.
Examples
properties:
  package:
    image: {get_input: magento-image}
    imagePullPolicy: {get_input: imagePullPolicy}
      env:
        - name: MYSQL_HOST # Specifies where MySQL is located.
          value:
            concat:
              - {get_input: mysql-name}
              - .default.svc.cluster.local # Actual address of MySQL, which is an internal domain name of Kubernetes.
        - name: MYSQL_USER
            value: {get_input: mysql-user}
        - name: MYSQL_PASSWORD
            value: {get_input: mysql-password}
        - name: MYSQL_DATABASE
            value: {get_input: mysql-database}
        - name: ACCESS_URL
            value:
              concat:
                - "http://"
                - {get_input: magento-EIP}
                - {get_input: magento-EPORT-s}
