- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
get_input
The get_input function is used to obtain the value of the input parameter defined in the inputs section of the template file. In addition, it can be used to reference system pseudo parameters. For details, see System Pseudo Parameters.
Syntax
get_input: [paramName ]
Parameter Description
Parameter |
Mandatory |
Description |
paramName |
Yes |
Name of the input parameter defined in the inputs section of the template file. |
Return Value
Value of the parameter
Examples
The following shows how to use the get_input function to retrieve the value of a parameter in the inputs section:
tosca_definitions_version: cloud_tosca_version_1_0 inputs: name: default: test-vpc cidr: default: 10.0.0.0/8 node_templates: my-first-vpc: type: Cloud.VPC.VPC properties: name: {get_input: name} cidr: {get_input: cidr}
- Cloud.UserId: obtaining the user ID of the current stack creator.
- Cloud.ProjectId: obtaining the ID of the project to which the current stack belongs.
- Cloud.DomainId: obtaining the ID of the account to which the current stack belongs.
- Cloud.Region: obtaining the ID of the region where the current stack resides.
- Cloud.StackName: obtaining the name of the current stack.
System pseudo parameters can be used together with the mappings and get_in_map functions to obtain predefined configuration information.
For example, an ECS VM can be deployed in different regions. You can predefine images and VM specifications for different regions in the mapping table. During stack creation, you can run {get_input: Cloud.Region} to obtain the region where the current stack resides and obtain configuration information such as images and specifications from the mapping table.
mappings: regionMap: ae-ad-1: flavor: c2.medium image_id: f2003c7b-99c4-4616-be19-334beaca81b1 node_templates: myecs: type: Cloud.ECS.CloudServer properties: availabilityZone: ae-ad-1a flavor: get_in_map: - regionMap - get_input: Cloud.Region - flavor imageId: get_in_map: - regionMap - get_input: Cloud.Region - image_id ...
