Writing a Template to Create an ECS
This section describes how to create an Elastic Cloud Server (ECS), including a Virtual Private Cloud (VPC) and subnet by writing a template. An ECS is a computing server equipped with CPUs, memory, images, and Elastic Volume Service (EVS) disks. ECSs can be created on demand and supports auto scaling. A VPC provides logically isolated, configurable, and manageable virtual networks for your ECSs. One or more subnets are automatically created when you create a VPC.
At the end of this walkthrough, you will see the newly created ECS on the Cloud Server Console.
In this walkthrough, you will write a template in the YAML language. For more information about templates, see Template Reference.
In this section, you will complete the following steps:
- Step 1: Write a Template: Use the YAML language to write a template for creating an ECS, VPC, and subnet.
- Step 2: Create an ECS: Use the template to create an ECS, VPC, and subnet.
- Step 3: Delete Unnecessary Resources: Delete unnecessary stack to avoid unwanted charges.
- Write a simple template to create a VPC.
tosca_definitions_version: cloud_tosca_version_1_0 #Template version information node_templates: #Element object definition myvpc: #VPC type: Cloud.VPC.VPC properties: name: my-vpc #Name of the VPC cidr: '192.168.0.0/16' #VPC CIDR
This template includes:
- tosca_definitions_version: specifies the version of a template. Currently, only cloud_tosca_version_1_0 is supported by AOS.
- node_templates: defines the set of objects to be orchestrated in a template. In AOS, objects are used interchangeably with elements. An object can be an application or cloud service resource. In the preceding template, node_templates defines the myvpc VPC.
- type: specifies the type of an orchestration object. The value comes from the element type list and can be set to Cloud.*** (*** indicates the element name in the Resource Indexes). In the preceding template, the myvpc VPC type is Cloud.VPC.VPC.
- properties: defines element properties, which vary with element types. In the preceding template, the myvpc VPC has the names and cidr properties, which indicate the name and network segment of the VPC, respectively. For more information, see VPC.VPC.
- Define a subnet in the VPC. A VPC is a large network segment and is usually divided into several subnets. Define a subnet in the created VPC based on the preceding template.
tosca_definitions_version: cloud_tosca_version_1_0 #Template version information node_templates: #Element object definition myvpc: #VPC type: Cloud.VPC.VPC properties: name: my-vpc #Name of the VPC cidr: '192.168.0.0/16' #VPC CIDR mysubnet: #Subnet type: Cloud.VPC.Subnet properties: name: my-subnet #Name of the subnet cidr: '192.168.1.0/24' #Subnet CIDR gateway: 192.168.1.1 #Gateway of the subnet vpcId: #ID of the VPC to which the subnet belongs get_reference: myvpc dhcpEnable: true #Determines whether to enable the DHCP function for the subnet in the VPC. requirements: #Dependency between the subnet and VPC. - vpcId: node: myvpc
The requirements section specifies the elements that have dependencies with the current element. For example, define myvpc as a dependent node in the requirements section of the subnet because a subnet depends on a VPC.
- Define an ECS in the template.
tosca_definitions_version: cloud_tosca_version_1_0 #Template version information node_templates: #Element object definition myvpc: #VPC type: Cloud.VPC.VPC properties: name: my-vpc #Name of the VPC cidr: '192.168.0.0/16' #VPC CIDR mysubnet: #Subnet type: Cloud.VPC.Subnet properties: name: my-subnet #Name of the subnet cidr: '192.168.1.0/24' #Subnet CIDR gateway: 192.168.1.1 #Gateway of the subnet vpcId: #ID of the VPC to which the subnet belongs get_reference: myvpc dhcpEnable: true #Determines whether to enable the DHCP function for the subnet in the VPC. requirements: #Dependency between the subnet and VPC. - vpcId: node: myvpc myecs: #ECS type: Cloud.ECS.CloudServer properties: name: my-ecs #Name of the ECS instances: 1 #Number of created ECSs imageId: 60e757e9-1924-413e-b71f-b7b49bacd2ca #Image ID used by the ECS. In this template, the image ID is the ID of the system disk based on 64-bit CentOS 7.2. flavor: c2.large #Specifications of the ECS vpcId: #ID of the VPC to which the ECS belongs. Either a new or an existing VPC ID can be used. get_reference: myvpc #Obtains the dynamic attribute value of the associated element. availabilityZone: ae-ad-1a #AZ to which the ECS belongs nics: #NIC of the ECS - subnetId: get_reference: mysubnet rootVolume: #System disk configuration of the ECS volumeType: SATA #Common I/O disk type size: 40 #System disk size (unit: GB) requirements: #Dependency among the ECS, VPC, and subnet. - vpcId: node: myvpc - nics.subnetId: node: mysubnet
- Save the template as a local file myecs.yaml.
- Log in to the AOS console.
- In the navigation pane, choose My Templates, and then click Create Template.
- On the Upload File tab page, specify the following parameters, upload a local YAML file, and then click Create. The template details page is then displayed, showing the template information.
- Template: Enter a template name. Each template name must be globally unique. For example, set this parameter to myecs.
- Version: Set this parameter to 1.0.
- Select File: Upload the myecs.yaml file.
- In the navigation pane, choose My Templates. The myecs template is displayed in the template list.
- Click Create Stack in the Operation column of the myecs template.
- Set the stack information.
- Stack Name: Enter a unique stack name, for example, aos-ecs.
- Description: The description can be left blank.
- Click Next and check the stack information. If the stack information is correct, click Create Stack.
The stack details page is displayed, showing that the stack is being created. The stack includes a VPC, a subnet, and an ECS. It will take about 6 minutes to create the stack.
- Wait until the stack status becomes Normal. The VPC, subnet, and ECS are created and displayed in the stack element list.
Figure 1 Stack successfully created
- View the created cloud services.
- Choose Service List > Computing > Elastic Cloud Server. You will see the newly created ECS on the ECS list.
- Choose Service List > Network > Virtual Private Cloud. You will see the newly created VPC on the VPC list.
- Click the VPC name to show more details about the VPC. On the VPC details page, you will see that the subnet has been created in the VPC.
