- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Application Scenarios
Migrating Applications to the Cloud
Challenges
Migrating applications to the cloud involves repetitive work, such as the destruction and rebuild of environments and manually configuring new instances one by one when scaling out applications. Some operations could be time-consuming, such as creating databases or VMs, which usually take minutes to finish. You may have to wait longer when these demanding operations need to be performed one by one. In this case, automating the whole process can improve the migrating efficiency and free you from tedious work.
Solution
AOS enables you to schedule resources, define applications, and deploy services at the same time. With a few clicks, operations such as deployment and destruction can be automatically performed. The only thing you need to do is define your applications and corresponding resources through templates.
Advantages
- Easy to Use
Design your applications and schedule resources by writing templates. Organize and manage the service easily and efficiently.
- Highly efficient
Automatically deploy services and destruct environments with a few clicks. Get rid of repetitive work.
- Quick replication of applications
Applications and resources can be quickly replicated and deployed across different data centers. Templates allow you to quickly create identical applications.
ISV Service Provisioning
Challenges
Independent software vendors (ISVs) deliver software to their customers and have the software deployed in the cloud to provide services. The traditional delivery method is that ISVs provide the software code and platform building guides on their official websites for customers to download. This could be time demanding and costly, because customers have to create resources, configure networks, perform O&M, and manage updates all on themselves. In addition, the traditional method is complex and error-prone, as all the installation is performed manually.
Benefits
AOS templates enable ISVs to deliver software and required resources in a standard manner. By writing templates and deploying application through AOS, software can be easily delivered and efficiently deployed with a few clicks.
Advantages
- Fast delivery
AOS automatically deploys the software and provisions the resources as specified in the templates you write. The whole process only takes minutes to accomplish.
- Error proofing creation
All the required resources for the software are defined in the template, which is fixed during delivery and deployment. In this way, mistakes introduced through manual work can be effectively prevented.
- Unified O&M
AOS enables you to perform software lifecycle operations, including updating and scaling, in a unified and easy manner.
Creating Resources in Batches
Challenges
Assume that you need to create a web application which runs on ten ECSs of different specifications, or you want to create ten databases, you have to create each of them one by one separately, and make sure they can properly work together. The whole process could be complicated and time consuming.
Benefits
With AOS, you can define multiple resources of different services and different specifications in batches in templates, which highly boost the deployment efficiency and brings much more flexibility during configuration.
Advantages
- Quick deployment
Multiple cloud resources of various types or the same type of resources of different specifications can be created concurrently.
- Flexible configuration
A wide variety of template syntax allows you to flexibly create and configure resources of various types and specifications.
- Automatic rollback
When the creation of resources in batches fails, you can choose to perform automatic rollback to save costs.
