- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Show all
Introduction
Application Orchestration Service (AOS) enables enterprises to automate application cloudification. By orchestrating mainstream cloud services, you can create, replicate, and migrate your applications and provision required cloud resources with a few clicks.
To work with AOS, all you need to do is create a template describing the applications and cloud resources that you would like, including their dependencies and references. AOS will then set up these applications and resources as specified in your template. For example, suppose you want to create an Elastic Cloud Server (ECS), together with a Virtual Private Cloud (VPC) and a subnet on which the ECS runs, you simply create a template defining an ECS, a VPC, a subnet, and their dependencies. AOS will then create a stack, namely, a collection of resources you specified in the template. After the stack has been successfully created, the ECS, VPC, and subnet are available to use.
AOS templates are text files that are easy to read and write. You can edit template files in YAML or JSON format.
AOS manages cloud resources and applications in a unified manner through stacks. During stack creation, AOS automatically configures the cloud resources and applications specified in the template. You can view the status and alarms of cloud resources or applications in a stack. You can create, delete, and copy cloud resources and applications by performing corresponding operations on stacks as a unit.
You can work with AOS on Console or through API.
Features
- Automatic orchestration of resources
AOS provides automatic orchestration of mainstream public cloud services. For list on the cloud resources that can be orchestrated, see Resource Indexes. AOS also provides lifecycle management including resource scheduling, application design, deployment, and modification to reduce O&M costs through automation.
- Hybrid orchestration of applications and cloud service resources
You can use standard languages, namely YAML and JSON, to describe required basic resources, application systems, upper-layer services, and their relationships. Based on your description, resource provision, application deployment, and service loading can be automatically performed in the order specified by dependencies with a few clicks. You can perform unified management on deployed resources and applications like deletion, scaling, replication, and migration.
