Updated on 2025-01-22 GMT+08:00
var_samp
This function is used to return the sample variance of a specified column.
Syntax
var_samp(col)
Parameters
Table 1 Parameter
Mandatory
col
Yes
Columns with a data type of numeric.
If the values are of any other type, NULL is returned.
Return Values
The return value is of the DOUBLE type.
Example Code
  • Calculates the sample variance of all offering inventories (items). An example command is as follows:
    select var_samp(items) from warehouse;
    The command output is as follows:
    _c0
    294.342355
  • When used with group by, it groups all offerings by warehouse (warehourseId) and returns the sample variance of the offering inventory (items) in the same group. An example command is as follows:
    select warehourseId, var_samp(items) from warehourse group by warehourseId;
    warehouseId _c1
    city1    18.23124
    city2    16.23344
    city3    11.43425
