repeat
This function is used to return the string after str is repeated for n times.
Syntax
repeat(string <str>, bigint <n>)
Parameters
Parameter |
Mandatory |
Type |
Description |
str |
Yes |
STRING |
If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is implicitly converted to the STRING type for calculation. |
n |
Yes |
BIGINT |
Number used for repetition |
Return Values
The return value is of the STRING type.
- If the value of str is not of the STRING, BIGINT, DOUBLE, DECIMAL, or DATETIME type, an error is reported.
- If the value of n is empty, an error is reported.
- If the value of str or n is NULL, NULL is returned.
Example Code
The value 123123 is returned after the string 123 is repeated twice.
SELECT repeat('123', 2);
