Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
regexp_substr
Updated on 2025-01-22 GMT+08:00
This function is used to return the substring that matches a specified pattern for the occurrence time, starting from start_position in the string source.
Syntax
regexp_substr(string <source>, string <pattern>[, bigint <start_position>[, bigint <occurrence>]])
Parameters
Table 1 Parameters
Mandatory
Type
source
Yes
STRING
String to be searched for
pattern
Yes
STRING
Constant or regular expression of the STRING type. Pattern to be matched.
start_position
No
BIGINT
Start position. The value must be greater than 0. If this parameter is not specified, the default value 1 is used, indicating that the matching starts from the first character of source.
occurrence
No
BIGINT
The value is a constant of the BIGINT type, which must be greater than 0. If it is not specified, the default value 1 is used, indicating that the substring matched for the first time is returned.
Return Values
The return value is of the STRING type.
  • If the value of pattern is an empty string, an error is reported.
  • If no match is found, NULL is returned.
  • If the value of start_position or occurrence is not of the BIGINT type or is less than or equal to 0, an error is reported.
  • If the value of source, pattern, start_position, occurrence, or return_option is NULL, NULL is returned.
Example Code
The value a is returned.
select regexp_substr('a1b2c3', '[a-z]');
The value b is returned.
select regexp_substr('a1b2c3', '[a-z]', 2, 1);
The value c is returned.
select regexp_substr('a1b2c3', '[a-z]', 2, 2);
The value NULL is returned.
select regexp_substr('a1b2c3', null);
