parse_url
Updated on 2025-01-22 GMT+08:00
This character is used to return the specified part of a given URL. Valid values of partToExtract include HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, and USERINFO.
For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'HOST') returns 'facebook.com'.
When the second parameter is set to QUERY, the third parameter can be used to extract the value of a specific parameter. For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'QUERY', 'k1') returns 'v1'.
Syntax
parse_url(string urlString, string partToExtract [, string keyToExtract])
Parameters
Table 1 Parameters
Mandatory
Type
urlString
Yes
STRING
URL. If the URL is invalid, an error is reported.
partToExtract
Yes
STRING
The value is case-insensitive and can be HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, or USERINFO.
keyToExtract
No
STRING
If the value of partToExtract is QUERY, the value is obtained based on the key.
Return Values
The return value is of the STRING type. The return rules are as follows:
  • If the value of urlString, partToExtract, or keyToExtract is NULL, NULL is returned.
  • If the value of partToExtract does not meet requirements, an error is reported.
Example Code
The value example.com is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'HOST');
The value /over/there/index.dtb is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'PATH');
The value animal is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'QUERY', 'type');
The value nose is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'REF');
The value file is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'PROTOCOL');
The value username@example.com:8042 is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'AUTHORITY');
The value username is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'USERINFO');
