instr
Updated on 2025-01-22 GMT+08:00
This function is used to return the index of substr that appears earliest in str.
It returns NULL if either of the arguments are NULL and returns 0 if substr does not exist in str. Note that the first character in str has index 1.
Similar function: instr1. The instr1 function is used to calculate the position of the substring str2 in the string str1. The instr1 function allows you to specify the start search position and the number of matching times.
Syntax
instr(string <str>, string <substr>)
Parameters
Table 1 Parameters
Mandatory
Type
str
Yes
STRING
Target string to be searched for
If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is implicitly converted to the STRING type for calculation. For other types of values, an error is reported.
substr
Yes
STRING
Substring to be matched
Return Values
The return value is of the BIGINT type.
  • If str2 is not found in str1, 0 is returned.
  • If str2 is an empty string, the matching is always successful. For example, select instr('abc',''); returns 1.
  • If the value of str1 or str2 is NULL, NULL is returned.
Example Code
  • Returns the position of character b in string abc. An example command is as follows:
    The value 2 is returned.
    select instr('abc', 'b');
  • The value of any input parameter is NULL. An example command is as follows:
    The value NULL is returned.
    select instr('abc', null)
