Cloud Data Center
DataArts Fabric
Cloud Transformation
Cloud Adoption Framework
Well-Architected Framework
CloudDevice
Cloud Container Instance (CCI)
Industry Video Management Service
Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
encode
Updated on 2025-01-22 GMT+08:00
This function is used to encode str in charset format.
Syntax
encode(string <str>, string <charset>)
Parameters
Table 1 Parameters
Mandatory
Type
str
Yes
STRING
At least two strings must be specified.
The value is of the STRING type. If the value is of the BIGINT, DECIMAL, DOUBLE, or DATETIME type, the value is implicitly converted to the STRING type for calculation.
charset
Yes
STRING
Encoding format.
The options are UTF-8, UTF-16, UTF-16LE, UTF-16BE, ISO-8859-1, and US-ASCII.
Return Values
The return value is of the BINARY type.
If the value of str or charset is NULL, NULL is returned.
Example Code
  • Encodes string abc in UTF-8 format. An example command is as follows:
    The value abc is returned.
    select encode("abc", "UTF-8");
  • The value of any input parameter is NULL. An example command is as follows:
    The return value is NULL.
    select encode("abc", null);
咨询盘古Doer
