datediff
Updated on 2025-01-22 GMT+08:00
This function is used to calculate the difference between date1 and date2.
Similar function: datediff1. The datediff1 function is used to calculate the difference between date1 and date2 and return the difference in a specified datepart.
Syntax
datediff(string date1, string date2)
Parameters
Table 1 Parameters
Mandatory
Type
date1
Yes
DATE
or
STRING
Minuend of the date difference between date1 and date2.
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
date2
Yes
DATE
or
STRING
Subtrahend of the date difference between date1 and date2.
  • yyyy-mm-dd
Return Values
The return value is of the BIGINT type.
  • If the values of date1 and date2 are not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the values of date1 and date2 are of the DATE or STRING type but are not in one of the supported formats, NULL is returned.
  • If the value of date1 is smaller than that of date2, the return value is a negative number.
  • If the value of date1 or date2 is NULL, NULL is returned.
Example Code
The value 10 is returned.
select datediff('2023-06-30 00:00:00', '2023-06-20 00:00:00');
The value 11 is returned.
select datediff(date '2023-05-21', date '2023-05-10');
The value NULL is returned.
select datediff(date '2023-05-21', null);
