acos
Updated on 2025-01-22 GMT+08:00
This function is used to return the arc cosine value of a given angle a.
Syntax
acos(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value range is [-1,1]. The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type. The value ranges from 0 to π.
  • If the value of a is not within the range [-1,1], NaN is returned.
  • If the value of a is NULL, NULL is returned.
Example Code
The value 3.141592653589793 is returned.
select acos(-1);
The value 0 is returned.
select acos(1);
The value NULL is returned.
select acos(null);
The value NAN is returned.
select acos(10);
