add_months
This function is used to calculate the date after a date value is increased by a specified number of months. That is, it calculates the data that is num_months after start_date.
Syntax
add_months(string start_date, int num_months)
Parameters
Parameter | Mandatory | Type | Description |
start_date | Yes | DATE or STRING | Start date The following formats are supported:
num_months | Yes | INT | Number of months to be added |
Return Values
The date that is num_months after start_date is returned, in the yyyy-mm-dd format.
The return value is of the DATE type.
- If the value of start_date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of start_date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of start_date is NULL, an error is reported.
- If the value of num_months is NULL, NULL is returned.
Example Code
The value 2023-05-26 is returned.
select add_months('2023-02-26',3); The value 2023-05-14 is returned.
select add_months('2023-02-14 21:30:00',3); The value NULL is returned.
select add_months('20230815',3); The value NULL is returned.
select add_months('2023-08-15 20:00:00',null); Feedback
