Forwarding WebSocket Services Using Dedicated Gateway
You can create WebSocket APIs using APIG same as creating an HTTP API. WebSocket is a protocol for full-duplex communication over a single TCP connection. It outweighs HTTP in real-time, two-way communication between the client and server, proving invaluable for applications such as instant messaging, online gaming, and real-time data update in the financial sector.
Restrictions
- WebSocket APIs cannot be debugged on the APIG console.
 - The WebSocket API has a timeout, and if the idle time of a WebSocket connection without ping/pong exceeds the configured timeout, the connection expires.
Prepare a WebSocket service backend for which ping/pong keepalive has been performed.
- Log in to the APIG console.
 - Select a gateway at the top of the navigation pane.
 - In the navigation pane, choose API Management > APIs.
 - Click Create API > Create API and configure the frontend.
Table 1 Frontend configuration Parameter
API Name
Enter a name that conforms to specific rules to facilitate search. For example, API01.
Group
The default option is DEFAULT.
URL
Method: Request method of the API. Set this parameter to GET.
Protocol: Request protocol of the API. Default: HTTPS, which corresponds to the WebSocket Secure (WSS).
Subdomain Name: The system automatically allocates a subdomain name to each API group for internal testing. The subdomain name can be accessed 1,000 times a day.
Path: Path for requesting the API. In this example, enter /hello.
Gateway Response
Select a response to be displayed if the gateway fails to process an API request. default is selected by default.
Authentication Mode
API authentication mode. Select None. (None: Not recommended for actual services. All users will be granted access to the API.)
 - Click Next and configure the backend information.
Table 2 Backend configuration Parameter
Backend Type
Select HTTP&HTTPS.
Load Balance Channel
Determine whether the backend service will be accessed using a load balance channel. For this example, select Skip.
URL
- Method: Request method of the API. Set this parameter to GET.
 - Protocol: Set this parameter to HTTP.
 - Backend Address: Address and port of the WebSocket backend service.
 - Path: Path of the backend service. In this example, enter /.
Timeout (ms)
Adjust the backend timeout to be longer than the ping/pong heartbeat interval. For example, if the ping/pong heartbeat interval is 20s, the timeout can be set to (20000 ms, 60000 ms].
 - Click Finish.
 - After the API is created, click Publish Latest Version on the APIs page to publish the API.
 - Use the API test tool to call the API.
In this practice, enter wss://IP address/hello to call an API in the DEFAULT group. The IP address is the EIP in the Gateway Information on the APIG console.
