General Procedure
- Configuring the API Frontend
Set the security authentication mode of the API frontend to Custom or enable Two-Factor Authentication (app or IAM authentication), and select a custom authorizer. If no custom authorizer is available, click Create Custom Authorizer.
- Configuring the API Backend
Add a policy for the backend. Set the Source of the Policy Conditions to System parameter - Frontend authentication parameter, and configure the Parameter Name, Condition Type, and Condition Value. The Parameter Name and Condition Value must be the same as the key-value pair in the context field in the return value of the frontend custom authentication function.
- Debugging the API
Debug the API and check whether the added policy backend is called.
