General Procedure
- Prepare CCE workload
Before opening a container workload with APIG, create a CCE cluster that uses the VPC network model or a Turbo cluster on the CCE console.
- Open CCE workload
Method 1: Create a load balance channel on APIG to access pod addresses in the CCE workload.
Method 2: Import a CCE workload to APIG. APIs and a load balance channel are generated and associated with each other to access pod IP addresses in the workload.
- (Optional) Configure workload label for grayscale release
Grayscale release is a service release policy that gradually switches traffic from an early version to a later version by specifying the traffic distribution weight.
