General Procedure
Assume that you have the following request throttling requirements for an API:
- The API can be called up to 10 times per 60s but can be called by a user only 5 times per 60s.
 - Only 10 requests containing header field Host=www.abc.com are allowed in 60s.
 - Only 10 requests with method GET and path reqPath = /list are allowed in 60s.
 - Only 10 requests with path reqPath = /fc are allowed in 60s.
 - Each excluded tenant can only call the API 5 times per 60s.
Following this procedure to create a request throttling 2.0 policy and bind it to an API.
- Create a policy.
Enter the basic information of the request throttling 2.0 policy.
 - Configure basic throttling.
Configure the basic throttling settings.
 - Configure parameter-based throttling.
Enable parameter-based throttling, and define parameters and rules.
 - Configure excluded throttling.
Enable excluded throttling, and configure excluded tenants and credentials.
 - Bind the policy to an API.
Bind the request throttling 2.0 policy to the API.
 - Verify the API.
Call the API and verify whether the request throttling 2.0 policy has taken effect.
