Check
Call the Check extension to use CodeArts Check capabilities.
Adding the Extension with GUI
Add the Check extension when you orchestrate a pipeline. Set parameters as shown in Table 1.
Parameter |
Description |
Name |
Extension name, which can be customized.
Select Task |
Select a code check task whose code source is the same repository as the pipeline you are configuring. |
Repository |
Select the corresponding code repository. |
Check Mode |
Code check mode. You can set check modes as needed to improve the check efficiency. |
Adding the Extension with YAML
Add the Check extension when you orchestrate a pipeline. Configure the YAML syntax as follows:
- Check
uses: CodeArtsCheck with: jobId: 43885d46e13d4bf583d3a648e9b39d1e checkMode: full|push_inc_full||push_multi_inc_full
- jobId: ID of a code check task.
- checkMode: Check mode.
- full: Checks all code.
- push_inc_full: Checks all files changed in this code commit.
- push_multi_inc_full: Checks all files changed between this code commit and the last successful code commit.
